D'oh!
stretchl
So along with some IC's and a coax I recently got some jumpers from Frank at Signal Cable.
The jumpers have banana plugs on the ends, which I requested.
Stoopid me forgot that since the MIT speaker cables have banana plugs I'll need some sort of splitter or Y adapter to plug in the jumpers to the posts with the incoming cable.
Googled it and saw nary a thing that looked like that.
Do they make 'em?
Thanks.
Do they make 'em?
Thanks.
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Post edited by stretchl on
Why not just change one end of the jumpers from bannana's to spades ?HT SYSTEM-
lsi 9's -
Here ya go: http://www.mitcables.com/iconn-connectors.html
The banana's come off as they are screwed on. You just take them off and get a set of iccon spades and your good to go.
Go with these: http://www.mitcables.com/available-in-stores/speaker-interfaces/iconn-regular-spade.html"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Forgot about that, good call my man. I knew I liked you for some reason.:cheesygrin:HT SYSTEM-
lsi 9's -
LOL.
A couple of regular Laurel and Hardy's, you two are.
Thanks, Dan.
Wish I'd had Frank just put spades on the jumpers. What a bone headed move asking for bananas.
Question -
Wouldn't these do... I mean, they're gold plated, too...“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
I just e-mailed Frank at Signal and he replied with this item, a banana-to-spade adapter -
http://www.amazon.com/Gino-Banana-Adapter-Speaker-Connector/dp/B006Z8NE18/ref=sr_1_4?ie=UTF8&qid=1346715881&sr=8-4&keywords=banana+plug+adapter“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
