wire gage question
laotzu61
laotzu61 Posts: 327
i currently have rta 12 speakers hooked up with 18 gage speaker wire from radio shack. until i can get cables from signal, would getting 14 gage wire from " accessories for less" make a difference? thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited September 2012
    I would recommend 14ga. 12ga if a very long run (say over 75 ft. or so)
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • laotzu61
    laotzu61 Posts: 327
    thankyou yet again, soundfreak1. i'll get the "ethereal" 14ga. from " accessories for less" 'till i can get my butt back to work, (hopefully this week sometime.) then i would like to get the cables from signal. i only need 3' from the kenwood to the speakers. thanks again.
    F1nut Posts: 51,922
    i currently have rta 12 speakers hooked up with 18 gage speaker wire from radio shack. Until i can get cables from signal, would getting 14 gage wire from " accessories for less" make a difference?
    ~No~
