Which speakers for home theater?
I bought a pair of Monitor30's for my TV viewing because the TV speakers were horrible. They made a world of difference. I want to complete a 5.1 system and have limited funds. I can get RTi6's and Monitor40's for the same price. Assuming I move the Monitor30's to the rear, which speaker is better for the front, the RTi6's or the Monitor40's?
Thanks for any advice you can provide.
Post edited by theslew on
no brainer, RTi6 of course for HT. did you know that RT stands for Reference Theater? I am using the RTi speakers too for HT, they're too bright for music though.
Does that mean concert Blurays will sound bad?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Mine sound awesome at reference level.Does that mean concert Blurays will sound bad?AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
if you use it for music a lot, I'd stick with Monitor series, or move up to Lsi. My friend has monitor 70 and sure way better with music than my Rti12. just easier to listen to for hrs w/o hurting my ears.
I have to question the associated gear if your going to state M70's sound better than RTI12's on music. Something isn't right with that scenario.HT SYSTEM-
lsi 9's -
My RTis sound fine with music as well. In theory a good concert BluRay should have the audio mixed to sound the best when used with a dedicated home theater. It's not an audio disk.AVR: Onkyo Tx-NR808
Rear: FXI A4
Somewhat confused now as I do watch concert videos and do listen to music channels. Would the RTi6's be that un-listenable to for music coupled with the Monitor30's?
RT = "Reference Theatre"...did you know that RT stands for Reference Theater?
RTi = "Reference Theatre Improved"
RTi A = "Reference Theatre Improved" (again). M16, M16A1, M16A2. the A1 is improved over the M16. the 'A2 is improved over the A1
Same true for unmodded RTi A series speakers. jbooker82's 'A7s modded by Trey. PM him... they're too bright for music though.
Shaloam, TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
My RTI4's sound good for anything I throw at them, for a bookshelf speaker, the RTI's are nice.
I have the RTIA7's but for the money you con't beat the RTI 8.Panasonic 65" Plasma - Panasonic Blu-ray. Onkyo TX-NR809 RTi A7s fronts - MK CS150s surronds.
RTis
