Hand Made Tube amp $290 shipped
onebadchad
I picked this little amp up about 6 months ago, and since then I have replace with Mcintosh, now it sits on shelf doing nothing so I hope someone will enjoy it as much as I have, it works perfect and sounds wonderful, has its own volume control so requires no pre-amp, works great with computer or Ipod or as standalone.. I was using some tannoy c-10 speakers but have tried many variations. Single ended has 6bq5/el64 and 6fq7 tubes. I am asking $290 shipped from Boise, Idaho.
all gold plated connections with point to point soldering
http://www.waamamps.com/waamampsstereotubeamplifiers.html
Made by Waamamps
Retail about $1000 new
I believe it is about 6 watts
works, looks and sounds wonderful
Thanks for looking,, Chad
Made by Waamamps
Hello Kitty am/fm CD player
Post edited by onebadchad on
yes, Inputs can use 6N1P 6922 6FQ7 6EV7 6GU7 6BQ7 6CG7 OR 6DJ8 OUTPUTS CAN USE 6P15P 6BQ5 EL84 OR SV83.Can the 6FQ7s be swapped for 6DJ8s?Hello Kitty am/fm CD player -
Well, that went quick. Cool amp! :cheesygrin:
I've chatted with Wayne from WaamampS before and he seemed like a knowledgeable guy. Looking forward to hearing one of his creations, and looking forward to hearing the horns with SE EL84!
Amp arrived last night and hooked it up. It seems to work fine and I'm excited to do a little exterimenting. Thanks!
exterimenting? gonna have to look that one up, lol... thanks again, hope you enjoyHello Kitty am/fm CD player
I think it usually requires much higher powered amps than this one to do that...
(or, at least a pair of Klipsch LaScalas).
