Convert 120v subwoofer to 220v
teju898
Hi Team.
I am new to this area.
I am planning to buy a polkaudio subwoofer from USA which can handle only 120v and do not have a voltage converter option in it. I live in India where we use 220v. I am planning to use a step down transformer which brings down the power from 220v to 120v.
I have few questions on this.
1) Can i do it? If yes, Is this the right way?
2) If i can do it, will there be any issue in the performance of the sub?
3) What are the long term maintenance?
IMHO you going to need a step up convertor which would change 220vac to 120vac.
http://www.amazon.com/Power-Bright-VC1000W-Voltage-Transformer/dp/B000MX564U/ref=sr_1_8?ie=UTF8&qid=1345554653&sr=8-8&keywords=120vac+to+220vac
This a 1000w version, maybe a bit overkill.... Caution of going too small like a 200w version.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
