Polk RTA 11t's What reciever/amp for them?
ipsullivan
New guy here, just trying to gain some knowledge before I spend money on the wrong equipment.
I just picked up a set of Polk RTA 11t's and my current Sony 5.1 receiver isn't going to cut it. I think I will be best suited with just a 2-channel set up. I have the Sony powered sub that came with receiver and the RTA 11t's.
What are my options?
-HDMI would be a plus, I would like to be able to run cable/xbox through the receiver as well.
Suggestions? What kind of power could I send to these?
Thanks,
Ian
Thanks,
Ian
Post edited by ipsullivan on
Welcome to Club Polk Ian!
Get whichever receiver that has all the bells & whistles that you want it to have and make sure it has preouts to add a separate amplifier.
For amplifier power get at least a 200wpc at 8ohms amp. Some good amps Parasound, Sunfire, Rotel, B&K, Nad, Adcom, Outlaw Audio, Emotiva. The last two are good bang for the buck brand new, and the others will be a great buy if you buy them used on Audiogon.com, here are some good choices.
http://app.audiogon.com/listings/rotel-rb-991-200-wpc-solid-state-power-amp
http://app.audiogon.com/listings/carver-sunfire-load-invariant-high-fidelity-stereo-powe
http://app.audiogon.com/listings/b-k-st-3030-200w-stereo-amp-w-balanced-intputs--2Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I appreciate the help. So am I just better off going with a receiver and an amp?
Could I get away with a receiver that is less wpc as long as the amp has higher wpc? I could save money on a receiver that is say, 75wpc instead of 125wpc.
Ian -
Yes, get a lower priced receiver that has preouts so that you can put that money towards an amp. The amp will allow your speakers to operate to their full potential.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I have the RTA-11TL's and find them pretty easy to drive with my Denon DRA-835R 2ch receiver from 1991 which is rated 100W into 8 ohms. I also tried my Denon AVR-888 which seemed up to the challenge but lacked the clarity and sound stage of the older, beefier Denon.
I assume the RTA-11T has similar specs to the TL.Stan
Main 2ch:
HT:
Other stuff:
Well, I picked up an amp and pre-amp today. I found a Yamaha M-65 and C-60 for sale locally. Wow, what an improvement.
That's a cool combination Ipsullivan.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I will post some pictures tomorrow at some point.
