$300-$350 used cdp?
Unknown
edited August 2012 in Going Digital
Looking to research this price category.
Currently using a Rotel 1093 with a rather expensive power cable and it is the shinnizle, but would like to research
some others for a future project.
I know you guys combined would have more info than starting the search cold, from scratch so I would appreciate your
comments on some memorable CDP's ($300-$350 used price) in this price range.
No external DAC at this time and I use coax connection.
Must have A/C IEC input, and coax out.
    SCompRacer Posts: 9,122
    edited August 2012
    A used Cambridge Audio 640C is usually found in your price range. Pretty sure on the IEC and coax out.
  • pietro944
    pietro944 Posts: 720
    edited August 2012
    I would look at the Shanling PCD 300B on ebay....New-$350 shipped......Has a nice headphone amp and uses the Burr-Brown PCM1735 Dac chip.....coax out with remote and removable power chord.
