RTi70 active or passive 2'nd driver
gmorris
gmorris Posts: 1,179
edited May 2004 in Speakers
I was reading the th'ds in the HOS, and read a post that said the RTi70 has one active driver and the other is passive. Is this a true statement? I was under the impression that both the 6-1/2" drivers are active.
Bob Mayo, on the keyboards. Bob Mayo.
Post edited by gmorris on
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2004
    I can't imagine Polk putting in an extra driver and not connecting it.
  • gmorris
    edited May 2004
    It would be called a passive radiator if it's not connected.
    I also think it is active, but this is based on no solid facts.
  • kingkip
    kingkip Posts: 401
    edited May 2004
    They are both active drivers. Look at the Rti12 or 10 on the bottom, those are what the passive radiators look like.
    There are two ways to argue with women. Both of them are wrong.
  • PolkThug
    edited May 2004
    Originally posted by kingkip
    They are both active drivers. Look at the Rti12 or 10 on the bottom, those are what the passive radiators look like. [/QUOUTE]
    Those are 7" drivers (or are you just saying that's what they could look like). Passive radiators on speakers I've owned were completely flat, with a rubber/foam surround.
    Regards,
    PT
  • faster100
    faster100 Posts: 6,124
    edited May 2004
    all the current polks have active drivers, The 70's i have seen inside and both are connected, the Rti150's are all also connected and not passive.. i have also removed a driver to check when i had mine.. all drivers work in the current models
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Pauly
    Pauly Posts: 4,519
    edited May 2004
    active yes...why would there be one passive and one active and the cab be ported?
    Life without music would
  • gmorris
    edited May 2004
    Thanks for all the input everyone.
    I guess it's no surprise the th'd I read that in has ended up in the HOS.
    VR3 Posts: 29,396
    edited May 2004
    In the old RTi70 discussions, the bottom midbass on the RTi70 was basically considered passive, as some people (I did for a while, until told otherwise) thought that the bottum woofer only played the lower freq. (2.5 way) - therefore, passive. Not really passive, was just considered passive.
    All in all, it is a 2 way as said above........
    Actually, mine is a 1 way. I unplugged the tweeters. Then I set the RT5 on top of it......me like. hehe, hope this explains it.
  • PolkThug
    edited May 2004
    Are the two 6 1/2's crossed over differently or the same?
    VR3 Posts: 29,396
    edited May 2004
    The same, I believe it is like 2.2khz or 2.3khz -- something around there. It is in the RTi70 section on the polk homepage in the specs...
  • gmorris
    edited May 2004
    Electrical
    Overall Frequency Response 28Hz-27kHz
    Lower -3dB Limit 40Hz
    Upper -3dB Limit 26kHz
    Nominal Impedance 8 ohms
    Recommended Amplifier Power 20-250 w/channel
    Efficiency 90 dB
    Crossover 2.1kHz between mid-bass drivers and tweeter; 2nd order HP/LP complement. Mylar bypass capacitor in HPF.
    Inputs Dual bi-amp 5-way binding posts
    Those are the specs from the RTi70 specs. page on the site. It seems the (2) 6-1/2" midbass drivers are operating at the same range. Thus, the design is a 2 way, not a 2.5 way.
    I guess I'll go home tonight and stick my ear right up next to the 2 midbasses, just to verify they are both playing.
