Proton d940 receiver common ground?
StevieB
StevieB Posts: 257
edited August 2012 in Electronics
Just picked one up, along with an old dual turntable. I was going to hook to some 1c's to test, but didn't know if it was ok. I searched and found an old thread about proton, but didn't address common ground status.
McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
Post edited by StevieB on
  • bmbguy
    bmbguy Posts: 416
    edited August 2012
    Easy enough to check it yourself if you've got an ohmmeter. Power off, and check for zero or very-near-zero ohms between the negative/minus speaker terminals.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited August 2012
    Can't say for sure on the d940 receiver model, but I had Proton D1200 power amp hooked up to SDA 2A speakers for several years, and they worked just fine. Do what bmbguy said, just to be on the safe side though.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    F1nut Posts: 51,737
    edited August 2012
    It's a receiver, it's common ground.
  • StevieB
    StevieB Posts: 257
    edited August 2012
    Thanks guys...it sounds surprisingly good through 1c's...may be the turntable though.
