Plugging Speaker Ports
mralexny
mralexny Posts: 39
edited August 2012 in DIY, Mods & Tweaks
Hi I'm Alex
I recently purchased a set of Polk Audio RTI A7's.
I brought them mainly for music playback but soon found out that they perform better in a HT configuration.
I later found out (through pain staking research) that plugging the ports (lower front and rear for bass and upper front for mids) would tighten the response of the drivers an turn them into a set of awesome music playback speakers; and it did.
I started with socks then move to form the I had custom made.
My question is can I use rubber stoppers instead of sock or foam?
I feel that this will prevent any air from escaping causing an even tighter driver response and turn the enclosure into a totally seal cabinet.
Side Note:
I have a Cerwin Vega cv-1800 amp (connected via a Nad 1155 preamp and im using an Ipad 3 for a Jukebox) that has more than enough power to drive them in this configuration; and as far a tv viewing I saw Battleship the other day and it was as good if not better than being at the theater.
Thank in advance
Current Configurations
Master Bed room:
Polk Audio RTI A7
Nad 1155 Preamp
Nad Stereo Tuner 4155
2 Cerwin Vega CV-1800
Panasonic 42 inch
PS3
Apple Ipad 3
Pure i-20
Alienware X51
DBX 234xs
Living Room:
Bose 301's
Nad 1155 Preamp
Nad 2200 Power Amp
Nad Stereo Tuner 4130
Panasonic 50 inch
Sony DVD Player
Apple iTouch 4
Post edited by mralexny on
  • nhhiep
    nhhiep Posts: 877
    edited August 2012
    this is interesting. Currently using Rti and Lsi speakers. I thought the reason why Rti isn't as good as Lsi for music is because of the tweeter (bright), not midrange or bass.
    yeah, Rti speakers are really good for HT
  • Face
    Face Posts: 14,340
    edited August 2012
    I presume you're using a sub? By plugging the ports you're killing the A7's low end response. As for how much, it depends on the driver parameters and enclosure size.
    Rubber stopper vs. foam, not a big difference.
  • mralexny
    mralexny Posts: 39
    edited August 2012
    I can barely go past the flat zone(50%) on the preamp without the bass overpowering the overall sound. NO SUB...
    The bass hits hard and tight(you feel it coming right at you---awesome for movies) ;and the mids have great clarity and transition.
    Amp set to full
    Preamp volume 3 sometimes 4 any higher I'll have to start charging club admission fees.lol
    I'm going to order the stoppers this week.
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • mralexny
    mralexny Posts: 39
    edited August 2012
    With my current configuraton I find the tweeter hi's to be right on.
    I can always tone them down a bit if I need to. I try to run flat as much as possible but some digital files need a little tweaking from time to time.
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • Face
    Face Posts: 14,340
    edited August 2012
    Are your speakers near boundaries(rear/side walls)?
    The woofers in the A7 probably have a high QTS.
  • mralexny
    mralexny Posts: 39
    edited August 2012
    Face wrote: »
    Yes on both counts
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
    edited August 2012
    Welcome to Club Polk!
    I have to agree with Mike, above. I've never heard anyone complain about lack of tightness on Rti bass. I have both versions of the bookshelves and the last thing I'd consider doing is plugging up their ports. These speakers already have a lot of R&D that went directly into those slim front ports and rear power ports?
    But whatever floats your boat. I'd mess around with room placement first, though!
    cnh
  • mralexny
    mralexny Posts: 39
    edited August 2012
    cnh wrote: »
    cnh
    Hearing the music and feeling it are 2 different things.
    I feel the mods I did brought the music to life.
    Remember Im not using them for home theater even though I may watch a movie on them once in while.
    I couldnt feel the music before I modded them.
    If you search around you'll find that alot of people have modified not just these but other speakers including small bookshelves.
    I also applied this mod to my Bose 301's and I can tell you that in all the years I've owned them they never sound so good.
    But everyone doesnt heat things the same as others. To each his or her own I guess.
    I appreciate the feed back.
    Quote
    "By their own nature, resonant systems cannot start and stop instantly. Ported speakers stagger two resonances, one from the driver and boxed air and another from the boxed air and port, in order to achieve their bass output, a more complex case than an equivalent sealed box. This causes increased time delay (increased group delay imposed by the twin resonances), both in the commencement of bass output and in its cessation. Therefore a flat steady-state bass response does not occur at the same time as the rest of the sonic output; rather, it starts later (lags) and accumulates over time as a longish resonant "tail". Because of this complex, frequency-dependent loading, ported enclosures generally result in poorer transient response at low frequencies than in well-designed sealed box systems"
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • Face
    Face Posts: 14,340
    edited August 2012
    cnh wrote: »
    cnh
    Since his speakers are corner loaded, it will explain why they sound better sealed. Generally, placing speakers near a boundary will reinforce low frequencies below 300(ish)hz, and will make them sound bloated if they were not designed for near wall use. Sealing them will cause the low end to roll off sooner, removing the bloated sound.
    mralexny wrote: »
    Quote
    Yes, but not the entire reason why they now sound better.
  • mralexny
    mralexny Posts: 39
    edited August 2012
    Ok guys
    Last night I pulled all the plugs and I agree they sounded alot better than when I first got them.(not as boomy)
    Most likely cause they have had alot of time to breakin. But the base hits felt as if they were coming from the room and not from the front of the speakers directed at me. In other words I couldnt feel the bass hit on me. The mids also were not as clear and pronounced especially when I switched to the Yankee game. Saturday I heard a couple of thump monitor 2 way speakers(sealed enclosure) in an outdoor enviroment with no wall behind them and I could feel the bass hits. I think its all about the way you want to experience the music you listen to; in other words subjective. I am however going to leave the plugs out for the rest of the week and see how it goes it could just be a listening curve for me. (me keeping an open mind or ear..lol) I'll keep you posted.
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • mralexny
    mralexny Posts: 39
    edited August 2012
    Hey guys
    Well the weekend is over; hope you all had a good one.
    Ok so here the thing I put the form plugs back in cause it definitly sounds much better.
    I also order thse rubber 3" and 1.2" inch stoppers to completely seal the cabinet bass and mid ports.
    Should get them this week.
    More to follow...
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • zingo
    zingo Posts: 11,258
    edited August 2012
    B&W provides foam port plugs on some of their models to tune the bass response. It's a good principle for tuning a speaker to a room, and more power to you if you like the outcome.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited August 2012
    Interesting that they spend all the time and research and it sounds better plugged.
    Kinda makes you want to just go select the parts and just build your own.
    Maybe it's because people expect that boomy sound some of the cars in the neighbor hood are like that.
  • mralexny
    mralexny Posts: 39
    edited August 2012
    When I decided to upgrade my old audio system I should have done more research on the type of speakers my paticular listen style of music required as well as what to expect from the 2 basic types of speaker enclosures. In hiensite I would of gotten a set of sealed enclosure 2 or 3 way speakers with at least 12 to 15 inch woofers by Cerwin Vega or even Thump to name a couple.
    Im sure for HT purposes these speakers out perform themselves; if thats even possible. And of course different strokes for different folks. Some people might like the boomyness. I prefer the more directed and tighter bass and midrange respone i'm getting with the plugs in place. They'll probably end up in my living room one day attached to that Pioneer Elite 52 I brought; setup up in a HT configuration maybe 5.1. But for now I'll just plug um and use um. lol..
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • mralexny
    mralexny Posts: 39
    edited August 2012
    Update
    So after installing the solid rubber stoppers both in the front an rear for sub ports and in the upper front mid port and the spearkers sounded lifeless. I had to really crank them up just to get some semi decent sound; by then they were to loud to enjoy.
    I removed the front plugs yesterday and today I will remove the rear plugs.
    I plan to reinstall the form plugs I started out with since I thought they really sounded great that way but I had to try the plugs for a totally sealed enclosure experience.
    As before I'll keep you posted...:biggrin:
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • steveinaz
    steveinaz Posts: 19,546
    edited August 2012
    Maybe try just foam-plugging the rear port, since you appear to be close to boundries.
  • drumminman
    drumminman Posts: 3,396
    edited August 2012
    Sounds to me like placement and room acoustics (shape of room, height of ceiling, placement of speakers, etc.) are playing a big role in the sound. Have you considered room treatments?
  • steveinaz
    edited August 2012
    You'd be amazed what just a few inches can do to tighten up bass.
  • mralexny
    mralexny Posts: 39
    edited August 2012
    steveinaz wrote: »
    Tried that and it was still boomy and not at all tighter.
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • mralexny
    mralexny Posts: 39
    edited August 2012
    drumminman wrote: »
    Rooms to small and there is a lot of furniture close together.
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
  • mralexny
    mralexny Posts: 39
    edited August 2012
    steveinaz wrote: »
    Master Bed room:
    Polk Audio RTI A7
    Nad 1155 Preamp
    Panasonic 42 inch
    PS3
    Apple Ipad 3
    Pure i-20
    Alienware X51
    DBX 234xs
    Living Room:
    Bose 301's
    Nad 1155 Preamp
    Nad 2200 Power Amp
    Panasonic 50 inch
    Sony DVD Player
    Apple iTouch 4
