Component to HDMI upscaler
Jimbo18
Jimbo18 Posts: 2,348
edited August 2012 in Electronics
In one bedroom, I have an older Phillips 1080P HDTV. Connected to it, is a digital converter box but one that is not HD and does not have HDMI output.
I would like to try to upscale the component output to 720P or 1080P if possible but my receiver doesn't upscale so I have been researching component to HDMI upscaling switching boxes and there are a lot of them available online but the reviews on them are all mixed.
Does anyone know of any under say about $200 that work well? I know most people on here have AVR with upscaling built in but I am not ready to upgrade the Pioneer receiver yet. I also wondered if a DVD recorder with HDMI output would upscale the signal.
Post edited by Jimbo18 on
    tonyb Posts: 33,068
    edited August 2012
    Those switches usually degrade the signal in some fashion, hence the not so hot reviews. For 100 bucks more, you can find a nice Pioneer 21 vhx, with the upscaling, hdmi, and all the newer surround formats. Save your pennies and upgrade the receiver.
  • Jimbo18
    edited August 2012
    Yeah, that's what I figured. I keep reading mixed reviews on the switches. I got the VSX 821K for about half price and couldn't pass it up. Never gave upscaling a thought at time. I suppose it would be better to sell it on CL and go with a better receiver.
    tonyb Posts: 33,068
    edited August 2012
    Atta boy, now your talking turkey. Good luck to you.
  • GregFilipozith
    GregFilipozith Posts: 1
    edited August 2012
    Jimbo18 wrote: »
    You are absolutely right.If it comes for about half price then it couldn't be passed up.
  • Jimbo18
    edited August 2012
    I paid $125 NiB for the Pioneer. Someone bought it and decided they wanted to go a different way even before they opened the box. I think it's a better receiver than I am using downstairs though, so I might try to sell the Yamaha and swap them out.
    Any suggestions for a $300 reciever that does a decent job of upscaling? Doesn't have to have pre-outs because I really can't see me going that way in the bedroom.
  • pdxfj
    pdxfj Posts: 376
    edited August 2012
    You could check out http://www.accessories4less.com
    They have an Onkyo 609 referb for just over $300. Onkyo started using the Marvell Qdeo chip with the x09 series of AVR's which is a very good 4k upscaling video chip.
    There are other AVRs from Denon, Marantz, Sherwood, etc.
  • Jimbo18
    edited August 2012
    Thanks pdxfj. I have been to that site after reading about it on this board several times. Wish I had known about it before I bought the Yamaha. I did research it before buying and liked what I read, but unfortuantely I wasn't educated enough in AVRs to make the best choice.
    I think I will list the Yamaha on CL and if/when it sells, move the Pioneer downstairs where I don't need the upscaling anyway. I have a decent Sony STR DE845 I can use in the bedroom till I replace the Yamaha.
