Hope to hook up LSi15's in a couple of days
stretchl
stretchl Posts: 1,334
Im now driving back to Illinois with a pair of LSi15's in the back seat of my car. My Adcom GFA-555ii should be there by the time I arrive.
After I get some under-the-floor measurements done, I'm going to get some new speaker cable from Frank at Signal Cable. But I will sure want to hook things up in a temporary fashion before I get those measurements done and that cable in. So...
The posts on the back of the LSi's look different that those on the 10b's, for which I just use bare ends of Radio Shack stereo cable.
Is it possible to use this wire on the LSi's? If so, how? Do the posts on the LSi's unscrew somehow that I'm not seeing?
Thanks very much.
Sign me, "Chomping at the Bit"
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
Post edited by stretchl on
    EndersShadow Posts: 17,704
    edited July 2012
    Shouldn't be a problem. The LSi's have a hole in the middle of the binding post. Unscrew the top piece till you can thread the wire through that hole and then screw it back down. Done
  • stretchl
    edited July 2012
    Thanks Ender there are two pairs of posts. Does it matter which I use?
    - Isaac Asimov
    Hi-Fi
    Visuals
    edited July 2012
    stretchl wrote: »
    Do you have the brass jumper that connects both sets of posts? If not you will need a short run of wire to connect to the other set of binding posts your speaker wire isnt in like below
  • stretchl
    edited July 2012
    I don't have the jumpers. Should I order a set of these from Signal Cable, also?
    Meanwhile, I'm guessing I can just use a short piece of speaker wire?
    Thanks.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • nwohlford
    nwohlford Posts: 700
    edited July 2012
    Yes, a short piece of wire will work perfectly.
    edited July 2012
    And you could either have Frank make you jumpers or have him make you bi-wire speaker cables either works
