Von Schweikert Audio LCR-15 Full-range Dialog Speaker
MKZ
MKZ Posts: 1,068
edited August 2012 in For Sale (FS) Classifieds
Von Schweikert Audio LCR-15 Full-range Dialog Speaker - 6/10 - $275 + Shipping From NY
SYSTEM TYPE: Shielded quasi three-way full range dialogue/general purpose speaker system. One of the two woofers is used for bass only, while the second is used for midbass and midrange. Can be placed horizontally or vertically. The optional VR-Stand may also be used.
BASS LOADING: Aperiodic Pressure Release design using 100% stuffing density. Note that the vents are not bass reflex ports, but act as pressure release orifices. Can be placed inside a wall unit.
BASS DRIVERS: 2pc --5.5" heavy- duty bass/mids with cast frame, cellulose acetate pulp cones impregnated with mica substrate and damped with a carbon fiber/resin polymer, Low Distortion Motor system, butyl rubber surrounds, long throw spider, high temperature voice coil and magnetic shielding. This new driver design has a very natural sound quality with inaudible coloration or distortion.
TWEETER: 1" - composite silk/polymer resin dome with Ferrofluid liquid cooling, high temperature voice coil, Low Distortion Motor design, and magnetic shielding. This tweeter is very musical, without harshness, even at high volume levels that would cause "standard" tweeters to distort.
CROSSOVER: Global Axis Integration Network (synthesized steep filters with phase-consistent behavior) with 220 Hz and 2.2 kHz crossover points. This crossover design has been engineered to radiate sound in a wide "bubble" instead of a "beam," so that phase and frequency response does not radically change off-axis. The audiophile-quality parts have been hand selected, including polypropylene capacitors and premium air core inductors.
BINDING POSTS: High quality audiophile five-way binding posts with rhodium plating.
FREQUENCY RESPONSE: 35 Hz to 25 kHz, (-6dB points, in room).
SENSITIVITY: 87.5 dB @ one watt/one meter.
POWER HANDLING: 8 watts min., 200 watts peak
IMPEDANCE: 8 ohms nominal (7 ohm minimum, 19 ohms maximum). SET friendly!
WARRANTY: Ten years parts and labor, excluding abuse such as burnt voice coils.
WEIGHT: 28 lbs packed for shipping, 20 lbs raw.
DIMENSIONS: 17.5" Wide x 10.25" Deep x 7.5" High (horizontally placed).
FINISHES: Black ash, dark red cherry, blonde maple, and African Hazelwood.
Does not have the Grill. There is a small cosmetic flaw at the top right corner, does not affect sound quality.
Includes: Original Box and Valvet pouch.
Post edited by MKZ on
  • maxchau
    maxchau Posts: 138
    edited July 2012
    great deal!
    Abbas Tube USB-SPDIF Converter with tube clocksAbbas V2 SE Tube DACAltmann Attraction DACNon-Pre passive preampYamaha M2 AmplifierDIY TPA3255 Mono Amps6L6 Williamson amplifier42 SET amp6V6 SET ampMcIntosh XRT18 speakersApogee Centaur MinorPioneer PAX A30 speakers
  • MKZ
    MKZ Posts: 1,068
    edited August 2012
  • Is this still available?
  • ken brydson
    ken brydson Posts: 9,002
    mkmarus wrote: »
    4 year old post dude. Doubtful...
  • hochpt21
    hochpt21 Posts: 5,423
    mkmarus wrote: »
    Dreamcrusher...
    :D
    F1nut Posts: 51,751
    MKZ was "Last Active March 2014"
  • ken brydson
    Yup. Gotta love Google...
    txcoastal1 Posts: 13,512
    Hifishark has Polk Classified listed
  • daboyz
    daboyz Posts: 5,207
