Peachtree iNova (Sabre 9016 DAC)
blueboxer
All,
I am listing my iNova for sale, it is in excellent condition and will ship in the factory box and packaging. This is the latest offering of the iNova and offers great performance for the price. The DAC alone is considered worth the price of admission by some, but the tube buffering and Class A preamp section are the real stars. It is listed at 80 Watts at 6 Ohms, but I have powered both Mythos ST and Polk LSi speakers with it with no problems whatsoever. I would love to keep it, but I just went with a Pioneer Elite 63 to finish off my upstairs room and need the funds to get the dedicated seats. Asking $1100 shipped, which is a 150-200 less than the 'gon typically sees. I will attempt to post up some pictures soon, but it is the piano black finish with fairly minimal use on it.
iNova Specifications:
Amplifier
80 Watts per Channel <1% Distortion into 6 Ohms
ST MOSFET Amp Modules
Sigma Servo Internal Wiring Configuration
Preamplifier
Hybrid Tube Design Using Triode (Stereo 6n1p)
7.0V Output at 2.0V Input
<1 Ohm at Output Stage
Class A Output Stage
Polypropylene Caps in the signal path
Headphone Amplifier (Shared with the Pre-Out Stage)
Suitable for All Electro-dynamic Headphones
Output impedance: <1 Ohm
Maximum Output Power:100Mw/8 Ohms/300Mw/150 Ohms/150Mw/300 Ohms
6N1P Vacuum Tube in Circuit
Digital to Analog Converter (DAC)
6 Digital Inputs: 1 USB, 2 Coax, 2 Optical, 1 iPod Dock
ESS 9016 Sabre DAC
USB 24Bit/96kHz
SPDIF 24Bit/192kHz
11 Regulated Power Supplies
Transformer-Coupled Digital Inputs
Galvanically Isolated USB Stage
>122dB Signal to Noise Ratio without Tube
Picoseconds Jitter Measured at the Master Clock
Amplifier
Preamplifier
ESS 9016 Sabre DAC
USB 24Bit/96kHz
SPDIF 24Bit/192kHz
Post edited by blueboxer on
Quick bump before off to the 'gon.
$1050 shipped for a great unit. All original packaging and accessories are included in like new condition.
I have only used the stock tube, which definitely adds a smoother warmer sound overall. I would assume superior tubes would only magnify this effect. The unit powered both Mythos STS and LSi15's without any issue. The pairing with the LSi's was the best match, but it really did a good job of taking the brightness of the STS away. The DAC/iPod dock is worth it alone, but the performance of the amp section is excellent as well.
Last bump.
