Polk Audio LSi15 Crossover Modification Thread
VR3
Coming soon!
Clarity Cap SA, PX, ESA, Mundorf Resistors! Should be fun!
Post edited by VR3 on
Your a busy man lately good for you vr3.
Way to busy!
I only make threads for "New" mods - hardly for the repeats! Juggling like 5 crossovers right now!
Thanks!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Parts, Stock Crossovers + random part from Legacy Empire crossover! :-P- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey out of overall curiosity PM me the cost of the upgrade."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Woofer/Midbass Network
This is a TOUGH modification... definitely had to be creative on parts placement- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey, do you have the actual speakers there to mount the crossovers in? They look like they could be kinda tricky to mount..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I do not...
What would be tricky about it?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I see what might be tricky...
Looks like I might only have 5" of play here till I might run into a port!
Interesting - requesting pictures from the owner with measurements now...
Maybe remote mount the tweeter network!
Yup lol they almost require either external mounting or having the cabinet to mount in as well. Big PITA as a result IMHO."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Well the enclosure is 13 3/8 - I assume by pictures the part is center mounted and the port is probably no bigger than 2.5" - that leaves me roughly 5.18 of mounting depth - lots of assuming here...
If that is the case, I am currently at exactly 5"
So I stop NOW, cut the rods - we can remote mount the tweeter network which should be easy as pie...
Basically drop in the crossover and either hot glue or velcro the tweeter network into place - you would have to remove the woofer to do it...
We will make it happen!
Keep pluggin...I am rooting for you for selfish reasons :cheesygrin:2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
Already for a solution - just waiting for a confirmation!
Going to do a 6x8 breadboard, going to do a stack for the midbass/woofer network and layout the tweeter network around it - use rubber feet to suspend it off the cabinet walls and mount it right above the woofer - should have plenty of space!
I was wondering if there is a point where one would be better off abandoning the original crossover mount on the terminal cup and make a new PC board? It seems that there would be plenty of room to mount a board on the back wall. On smaller enclosures is it ok to go external?
StanStan
Main 2ch:
HT:
Other stuff:
external would drastically increase the costs of the modifications...
Going with a remote mounted perfboard seems to be the way to go- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
We are pretty sure this configuration will work...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Looks like the above configuration mounted on the rear or front wall is going to be the winner!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I have some pics I can post later that may help. You can search for them too, I've posted them here before."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
After many back and forth emails, a phone call and a few MS Paint diagrams I believe this is the winner for this first LSi15 modification...
A mirrior imaged set of these crossovers will fit perfectly in the midbass enclosure..
! - Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here's what I ended up with. Not very easy to shoehorn inside, but it worked.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Very nice!
Yep...
Given the budget of the owner I believe these turned out well...
If another $150-200 was thrown at them it would be cool to replace the inductors and larger values straight up...
Mirror imaged pair!
Just gotta attach the driver wire and test these bad boys out!
Free air test..
SOUNDS GREAT!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
This is not my cleanest modification unfortunately just because all of the component were mounted and I had to unmount them and start over -
However, I walk away with a modification anyone can install in their speakers, period...
So... yeah!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My official internal LSi15 modification, woofer network!
Tweeter network, nice and compact- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Testing!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Pictures taken on top of Bill's immaculate rack!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Nice work!
