Power cord recomendation
acmf74
I need a power cord for my pre-amp and CDP. Can someone recommend me a brand that inst too thick?
I'd like to keep it around $50 for each and around 6ft,
Thanks,
Thanks,
Post edited by acmf74 on
Pangea PGAC14SE about $60 for 1m, a bit more for 2m
and if you don't get the se the price drops. buy through amazon for free shipping.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Thanks. I'll take a look at both.
Give pepster a PM. I'm sure he can help ya out.
I am not so sure its going to be under 50 though since he needs a 6 footer. Give him a try though, he made a cable for me and I like it. I am using it on my Integra which is being used as a pre, but it sure feels much beefier than the stock one
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
it appears that the ac14 se models in the two meter are all sold out
are the SE models really worth the premium? -
I picked up the pangea ac14se for my CDP and really like the results. I know the ac9 is made for amps but it might be too big for my tight area. Will the ac14se be suitable for a amp use?
Try Signal Cable (Frank)
Great reviews/Great value.
I cant speak to it personally but def give them a look.
I bought 3 power cords from them based on my research. Haven't been able to hook them up yet. HT still under construction.
Good luck.HOME THEATER 5.1
JVC DLARS56U
92" SI Black Diamond 1.4 16:9
NAD M25 MC Power Amp
Marantz AV7005 Pre Amp
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
LSIM 707 (2 Channel Sessions)
McIntosh MC312
McIntosh C49 Preamp
Marantz SA8005 SACD/CD Player
79' Pioneer SX-1080
Furman Elite 15 PC
SolidSteele HF-4 series rack
REL Carbon Special Purple Label
(Building system out currently)
(Use Quobuz almost exclusively - CD/SACD Part time)
OUTDOOR DECK
NAD C 375BEE DAQ
PSB CS 1000 Speakers
Sonos
Signal Cable - Ultra Single (Banana), Magic Power Cord, Dig Power, Vid Power.
RTi T3-V+, SONOS, Furman Power Conditioner -
I like the old PS Audio Prelude simply because it has a smaller diameter plug housing then most power cords; plus a removable ground pins that can be handy. Used prices can be decent, and within your price range.
