Power cord recomendation
acmf74
acmf74 Posts: 937
edited December 2012 in Basic Hookup/Wiring Questions
I need a power cord for my pre-amp and CDP. Can someone recommend me a brand that inst too thick?
I'd like to keep it around $50 for each and around 6ft,
Thanks,
Post edited by acmf74 on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2012
    Pangea PGAC14SE about $60 for 1m, a bit more for 2m
  • rooftop59
    rooftop59 Posts: 8,120
    edited July 2012
    and if you don't get the se the price drops. buy through amazon for free shipping.
    Game Room 5.1.4:
    Bedroom 2.1
  • acmf74
    acmf74 Posts: 937
    edited July 2012
    Thanks. I'll take a look at both.
  • chumlie
    chumlie Posts: 8,658
    edited July 2012
    Give pepster a PM. I'm sure he can help ya out.
    EndersShadow Posts: 17,713
    edited July 2012
    chumlie wrote: »
    I am not so sure its going to be under 50 though since he needs a 6 footer. Give him a try though, he made a cable for me and I like it. I am using it on my Integra which is being used as a pre, but it sure feels much beefier than the stock one :smile:
  • acmf74
    acmf74 Posts: 937
    edited July 2012
    it appears that the ac14 se models in the two meter are all sold out
    are the SE models really worth the premium?
  • acmf74
    acmf74 Posts: 937
    I picked up the pangea ac14se for my CDP and really like the results. I know the ac9 is made for amps but it might be too big for my tight area. Will the ac14se be suitable for a amp use?
  • RocketOCannon
    RocketOCannon Posts: 86
    Try Signal Cable (Frank)
    Great reviews/Great value.
    I cant speak to it personally but def give them a look.
    I bought 3 power cords from them based on my research. Haven't been able to hook them up yet. HT still under construction.
    Good luck.
    HOME THEATER 5.1
    JVC DLARS56U
    92" SI Black Diamond 1.4 16:9
    NAD M25 MC Power Amp
    Marantz AV7005 Pre Amp
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    LSIM 707 (2 Channel Sessions)
    McIntosh MC312
    McIntosh C49 Preamp
    Marantz SA8005 SACD/CD Player
    79' Pioneer SX-1080
    Furman Elite 15 PC
    SolidSteele HF-4 series rack
    REL Carbon Special Purple Label
    (Building system out currently)
    (Use Quobuz almost exclusively - CD/SACD Part time)
    OUTDOOR DECK
    NAD C 375BEE DAQ
    PSB CS 1000 Speakers
    Sonos
    Signal Cable - Ultra Single (Banana), Magic Power Cord, Dig Power, Vid Power.
    RTi T3-V+, SONOS, Furman Power Conditioner
  • zingo
    zingo Posts: 11,258
    I like the old PS Audio Prelude simply because it has a smaller diameter plug housing then most power cords; plus a removable ground pins that can be handy. Used prices can be decent, and within your price range.
