Wiring a PSW 150
Ericjump
I just purchased a PSW 150 and am looking for help with basic wiring and set up.
Can I access a user manual anywhere.
Thanks in advance
Thanks in advance
Post edited by Ericjump on
Hello Eric,
Thanks for posting on Polk's forum. I did a search, on Polk's web site, and only found a general description for the 150, but no owner's manual. Polk's CS department might have an original copy they could send, give them a call on Monday at 1-800-377-7655. In general terms, if your receiver has a sub-out connection use a single RCA cable to go from the receiver's sub-out to either the right or left (or LFE if it has one). If there's no LFE input on the sub rotate the variable low pass filter to the highest setting. Go into the receiver's setup menu and turn the sub-out function on. If the receiver has an automatic settings program use it to balance the sub's volume.
Regards, Ken -
It has standard stereo L/R RCA input, passive in/out in stereo, and volume+crossover knobs. I have this one at home
Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
try downloading one of polks PSW line of subs from here:
http://www.polkaudio.com/home/library/manuals.php?category=7&speaker=418
Also please look at this old thread.
http://www.polkaudio.com/forums/archive/index.php/t-29780.html -
Polk is also very good at Emailing manuals as well, That's how I got the Manual for my RM1000W, took a day or so.
