Wiring a PSW 150
I just purchased a PSW 150 and am looking for help with basic wiring and set up.
Can I access a user manual anywhere.
Thanks in advance
Post edited by Ericjump on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited July 2012
    Hello Eric,
    Thanks for posting on Polk's forum. I did a search, on Polk's web site, and only found a general description for the 150, but no owner's manual. Polk's CS department might have an original copy they could send, give them a call on Monday at 1-800-377-7655. In general terms, if your receiver has a sub-out connection use a single RCA cable to go from the receiver's sub-out to either the right or left (or LFE if it has one). If there's no LFE input on the sub rotate the variable low pass filter to the highest setting. Go into the receiver's setup menu and turn the sub-out function on. If the receiver has an automatic settings program use it to balance the sub's volume.
    Regards, Ken
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2012
    It has standard stereo L/R RCA input, passive in/out in stereo, and volume+crossover knobs. I have this one at home :)
    Main Surround -
  • litezoner
    litezoner Posts: 13
    edited July 2012
  • litezoner
    litezoner Posts: 13
    edited July 2012
    Polk is also very good at Emailing manuals as well, That's how I got the Manual for my RM1000W, took a day or so.
