Packing advice for the forum!
VR3
VR3 Posts: 29,444
edited July 2012 in The Clubhouse
If you insist on using peanuts... might I suggest that if the speaker has a port to first wrap the speaker in plastic...
And... that is all!
Post edited by VR3 on
    Toolfan66 Posts: 18,077
    edited July 2012
    So what I see you saying is common sense should be used when packing speakers??
    EndersShadow Posts: 17,707
    edited July 2012
    VR3 wrote: »
    And... that is all!
    I thought the port was so you could fill the entire speaker with peanuts :biggrin: :cheesygrin:
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited July 2012
    Anything shipped should be wrapped and sealed in plastic first. No exceptions. Prevention of movement in the box is next. I'd rather see an inch of cardboard around something than the of use peanuts, which are useless. Cardboard and wood glue are your friends.
  • Jstas
    Jstas Posts: 14,985
    edited July 2012
    I like stuffing the speaker with packing peanuts! I get a smile on my face just thinking of the rage fit the new owner flies into when months after they thought they got them all, another one come shooting out of the port in the middle of "Lord of the Rings" or something!
    Expert Moron Extraordinaire
  • Systems
    Systems Posts: 14,873
    edited July 2012
    No silly, thats where you pour the sand to make them "dead"!:cheesygrin:
    Testing
    Testing
    Testing
  • brgman
    brgman Posts: 2,859
    edited July 2012
    pepster wrote: »
    If anybody knows packing it's pepster.
    I’M OFFENDED!!!!
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited July 2012
    I'd recommend 3 or 4 cans of expanding foam.
    nooshinjohn Posts: 25,932
    edited July 2012
    This might be a great idea to reduce magnet-shift on the SDA models.:wink:
    mhardy6647 Posts: 35,050
    edited July 2012
    The late John Wyckoff (Hammer Dynamics) recommended using peanuts as stuffing material for his "Super 12" speaker design (sold as a driver/XO kit). The ported speakers would occasionally puff a few odd peanuts from their ports when playing.
    http://www.enjoythemusic.com/magazine/equipment/0600/super12.htm
    http://www.hammerdynamics.com/ (I assume that the site is moribund; too bad, they were decent loudspeakers - based on the Eminence LT12 twincone driver)
