which speakers are right for application I
I have a denon 2312 just got the polk audio 505 subwoofer sounds great I need to upgrade my surrounds still running the 1 from my old system I understand the center speaker is different but are my front, side ,& rear speakers able to be the same I am thinking about buying 6 tsi 200 any input
Post edited by soundsgr8 on
I'd do Monitor 60, CS2, Monitor 30 surrounds. They'll work well with your avr and sub, and save you some cash over the Tsi's.
Seems monitor 30 speakers are a little less quality I have found a good deal on amazon on the tsi200 @$208 a pair and I don't mind spending this much on 3pairs just wondering if this would be a good set up or not
Up to you, I personally would spend a little more and look into the Rti series or i'd go with the monitor series and get better speakers than the Tsi200's. I don't see the need for all Tsi200's and think you can do better for the same $, but that's just my honest opinion.
Thx for the help I ended up going with the tsi200 4 my side and rears ,monitor 60 for front l/r cs20 for center and 505 sub
Nice! I think you'll be happy with that combo, let us know how it turns out.
