Where did the SDA go?
johndo18
I have a pair of 3.1Tl's which i use a Adcom GFA-555 to power them. I started off using an old Sony receiver as a preamp and i was using cheap old RCA cables. Now ive upgraded recently to a Yamaha HTR-5660 for a preamp and i'm using a Monster Optical cable. Its seems that the sound stage has defintaley opened up alot however that sweetspot that SDA's are know for has disappeared. I no longer hear the voices coming from between the speakers but it seems as the sweetspot widened alot. My question is could it be the Optical cable? or maybe i have some setting wrong on the yammy? I mean what made the sweetspot go away? Tom
Polk 3.1TL
Adcom Gfa-555
Yamaha HTR-5660
SVS 20-39 PC+
Adcom Gfa-555
Yamaha HTR-5660
SVS 20-39 PC+
Post edited by johndo18 on
Did you move the speakers at all? I find that the distance apart from each other can make a huge difference. (as little as 3 to 6" difference).Vinyl, the final frontier...
Sounds to me like the speakers are wired out of phase...More later,
Tour...
Vox Copuli
No i didnt move them or touch the speaker wires since the upgrade...can you guys think of anything else it could bePolk 3.1TL
Adcom Gfa-555
Yamaha HTR-5660
SVS 20-39 PC+ -
Thought you made the AVR and optical change at the same time. Apparently not...
Go back to the RCA's to the Yammie and see if the center stage reappears...More later,
Tour...
Vox Copuli
Double check your SDA cable. Make sure its still plugged in properly.
Do you have all the surround/signal processing modes turned off on the receiver? I am not familiar with your receiver, but I had a similar experince with a Yamaha HTR-5250 and a pair of SDA CRS+ speakers if any of the signal processing modes were engaged.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Ohh boy...looks like it turned out that one of the speakers was out of phase....some one slap me silly! Got it runnin now....I love my 3.1tl'
Go SDAPolk 3.1TL
Adcom Gfa-555
Yamaha HTR-5660
SVS 20-39 PC+ -
Looks like another good call by Tour2ma.
Glad you're back in SDA heaven.Political Correctness'.........defined
President of Club Polk -
Whad i win? Whad I win?More later,
Tour...
Vox Copuli
Congratulations Tour, you get a kick in the ****!
Well, at least it'll hurt less than a kick in the nuts...More later,
Tour...
Vox Copuli
