WTB: Polk Series II Monitor 30
myoung84
Where can I buy a new (or slightly used) Monitor 30? I already have 2 on the sides and need a 3rd for 6.1... Don't really want to buy a pair...
Post edited by myoung84 on
Anyone?
Sorry, but it is a little hard to come buy a single M-30. My suggestion would be to just get a pair off of newegg.com when they discount them to $89 and sell off the extra one to someone else who might need just one.
Is there some "reason" why you're not going 7.1 (in which case a pair would be exactly what you need)?
That's what I will most likely do, just wanted to check with the pros and see if there was an easy was to get a single.
Reason I'm not going with 7.1 is because they way my living room is set up. Everything is set at an angle and with the entry way and stair case, there's no feasible way to get 2 speakers behind me. I already have my two existing surrounds on the sides rather than the rear, so a single back surround will be perfect for my setup.
