polk tweets ID.
soundfreak1
soundfreak1 Posts: 3,414
edited June 2012 in Vintage Speakers
trying to confirm tweet model # ( not marked) monitor 10a ( as marked) mw6500 frivers dated 2/83. Also passive have no markings? Anyone what tweets and passuves are? Also if i
t helps the crossover is fused.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • kcoc321
    kcoc321 Posts: 1,788
    edited June 2012
    Tweeter is a Peerless.
    Passives for the Mon 10a are Sw100 ( or should be)
    http://www.tagged.com/apps/mafia.html?source=R#h=/character/5450520687/info
  • soundfreak1
    edited June 2012
    Thanks! Are they ( exchangeable ) with the sl2000 tweets in my 5jr+? That is without changing cap values.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    heiney9 Posts: 25,498
    edited June 2012
    No they are not. While the Peerless will work the electrical specifications and x-overs are different. It's not just a matter of cap values, IIRC most models that use the peerless have a extra resistor as well.
  • soundfreak1
    edited June 2012
    Oh well! They sound nice! Guess i will have to do the rdo194 OR 198. I KNOW THE CAP VALUE IS DIFF. FOR THE 198's.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
