Are These Monitors 10-A's or 10-B's? And, Any Upgrade Advice?
stretchl
stretchl Posts: 1,334
edited June 2012 in Vintage Speakers
Greetings, all. Great to find this forum.
I bought my Polk Audio Monitor 10's back in 1987 and I've loved them ever since. I've moved about a dozen times since then, always taken the Polks with me, and they're real survivors and still sound great.
I have a couple of questions -
1) How can I tell if these are 10A or 10B's? I've long forgotten which I bought. On the back of the speakers are the numbers "10 160240."
2) I'm thinking of upgrading the speakers. Can anyone recommend something that would be a noticeable improvement in sound and volume but not too terribly expensive? I use a Luxman R-115 tuner/amp with the speakers, purchased at the same time.
Thanks!
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
Post edited by stretchl on
  • TennMan
    TennMan Posts: 1,266
    edited June 2012
    Welcome to the forum! Show us a photo with the grilles off so we can help you figure out which model you have.
    edited June 2012
    Welcome to Club Polk!
    Sorry I can't identify Polk speakers by number. Pics would help!
    If you like the sound of vintage Polks you should really consider picking up some SDA 2Bs or 1Cs or higher! Wouldn't cost more than a few hundred dollars and would be the next step up from the monitors, unless you want to go "new"...and you'll have to pay there. Even the cheapest upper bookshelf Polks are 1500 a pair (LSi-M703).
    cnh
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited June 2012
    Welcome to Club Polk-
    pics or we are guessing? Is the tweeter black with a pinhole in the middle (peerless) or more of a silver colored soft dome (SL2000)?
  • stretchl
    edited June 2012
    Thanks, guys! Here's a photo of the front of the speaker. The tweeter, whose dome is sadly crushed a bit, says "Silver Coil Dome" on it.
    polk.jpg 150.4K
    - Isaac Asimov
    Hi-Fi
    Visuals
  • teekay0007
    teekay0007 Posts: 2,288
    edited June 2012
    Monitor 10Bs with SL-2000 tweeters.
  • stretchl
    edited June 2012
    Thanks!
    Just so I can get an idea of the range of possible options for my R-115...
    Say money is no barrier... what Polks would be the very best match for the amp?
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Drenis
    Drenis Posts: 2,871
    edited June 2012
    Whichever ones sound the best to you.
    You could upgrade your current speakers and take them to the best they can be or try something new. It's really up to you.
    Do you want something different or to improve on something you really like the sound of? Because you can...
  • stretchl
    edited June 2012
    What happens is I get to about ten o'clock on the volume of my R-115 and the speakers can't take any more. I'd love to be able to get more volume and more quality at low volume. Also, the footprint of my 10a's is a bit large for the space my wife and I are now in. (We just bought a house.)
    Would the RTi-A9's be too much speaker for the amp?
    Thanks again, and please forgive my naivet? when it comes to this. I bought my system back in '87 and this is the first time I've had a hankering to upgrade.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Drenis
    Drenis Posts: 2,871
    edited June 2012
    Since I don't know your listening habits and the characteristics of that amp other then a quick google search. I'm going to suggest you look at a pair of LSi15's. Seems you want to stay the size your at or go to a tower. Stay with a musical speaker.
    Prices are great for these through polks ebay site.
    edited June 2012
    10Bs! Yes!
    Hey, what's the Luxman receiver put out? 70 watts x 2? If so a more powerful amp would make even those 10Bs sing! Sounds like you're merely clipping the Luxman. The 10s can probably handle a lot more!
    Small footprint, yeah, LSis.
    Does the Luxman have L/R pre-outs because if so, just get yourself a nice used power amp around 150-200 watts a side or so (Rotel, Parasound, NAD, Carver, etc.) And use the Luxman as your Pre-amp for now! Probably get a decent amp for a few hundred? You'll thank us later? Maybe?
    BTW, Tweeter replacements for SL-2000s = RD-0194 available from Polk at about 50 a pop. Tell them you're a member! You will need two!
    cnh
  • stretchl
    edited June 2012
    Thanks, guys. The Luxman is 70 watts.
    What do you mean, I'm clipping it? I always thought the speakers were what was limiting the system, since the volume dial on the Luxman wasn't even up to twelve o'clock.
    The LSi15's have a perfect footprint for our space, but if I'm not going to hear any improvements due to the limitations of the Luxman, I can't justify spending the money.
    Thanks, and thanks for the tip on Polk's ebay store!
    ps - Music is much more important to me than movie sound effects, and I listen to a WIDE variety of stuff, though usually it tends toward pop music.
    - Isaac Asimov
    Hi-Fi
    Visuals
    edited June 2012
    A lot of people think that. But in most cases, the speakers are NOT the limiting factor and you don't have to have the volume control at full throttle to generate distortion, especially in an older unit that might need some recapping?
    LSi-15s? You DEFINITELY need a power amp of at least 200 watts by 2 for those.
    Have fun!
    cnh
  • stretchl
    edited June 2012
    Very interesting, CNH. Thanks so much.
    I don't know about the recapping, as I recall the quality topping out at about nine or ten o'clock on the volume even when the equipment was new.
    Looks like I need to do a lot more research in order to avoid wasting a lot of money.
    I really appreciate everyone's input here.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • TNHNDYMAN
    edited June 2012
    I'd need more time research your amp, but my 10's have handled a 200wpc amp very well. You are more likely to underpower the 10's and hurt them than you are overpowering them. You should leave the room with you ears ringing befrore the 10's give up. Sometimes I have to remove my grills because the drivers are hitting them during max excusion at high volumne.
    Depending on the vintage of your gear, that Luxman may need a good chk up by a good tech. I have a Luxman L80V connected to my 10's currently and it sounds superb- but I am sure it could use some caps replaced and I don't try to over do it. Keep the loudness switch off and tone controls flat and try it that way, my luxman tends to overemphasis the freq response when not left flat.
  • gwg_97
    gwg_97 Posts: 332
    edited June 2012
    I powered my 10Bs with a vintage Kenwood Basic M2A (220 wpc) for about 20 years. You can get this amp and a cheap pre amp for about $250 on the used market and I bet you will love the sound. Its not a Krell but is pretty bullet proof and sounds pretty good for the $. Also, you can clean those sticky/dusty drivers with a windex soaked rag and some gentle wiping. Be careful, you'll be spending a lot of $ before you know it :biggrin:
    System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
  • TNHNDYMAN
    edited June 2012
    ^ that's what I get for not refreshing the thread before posting. At least great minds think alike. The limiting factor here is most likely the Luxman as nice as they are and not the Polk 10's.
    They are worth the money to feed them a good source. At the end of the day you will need quality amplification to get the most out of any quality speaker you may choose.
  • stretchl
    edited June 2012
    sooooo... Is there a consensus that I should try the Luxman as a pre-amp with something more robust between it and the 10B's?
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Joe08867
    Joe08867 Posts: 3,919
    edited June 2012
    Yes to using the luxman as a preamp, since it does have preouts. The internal amps in most receivers can't hold a candle to a separate amp.
    Something from B&K, Rotel, Adcom, Parasound or NAD would be the best match to those speakers.
  • stretchl
    edited June 2012
    Thanks, Joe!
    I have a Rotel RCD-855 player, also bought in '87, which I love.
    So maybe I'll go with a Rotel amp...
    - Isaac Asimov
    Hi-Fi
    Visuals
  • stretchl
    edited June 2012
    The refurb lsi,s are under $900, the gfa around $300, the luxman I have on hand.
    Thoughts? thanks!
    - Isaac Asimov
    Hi-Fi
    Visuals
  • gdb
    gdb Posts: 6,012
    edited June 2012
    Don't disregard the ugly,****,red-haired, step child around here....Carver ! A lot of em have a warmish, almost "tubey" sound to em. :wink:
  • transmaster
    transmaster Posts: 424
    edited June 2012
    Spec's for the 10B's
    Electrical
    Overall Frequency Response 25Hz - 25kHz
    Lower -3dB Limit 37Hz
    Upper -3dB Limit 25kHz
    Nominal Impedance 8 ohms
    Recommended Amplifier Power 20-250 w/channel
    Efficiency 89 dB
    Radio Station W7ITC
