Adcom GFA 7500 channel problem
gwh
Had my center channel unplugged on the speaker side and the wires touched, thought I had the amp turned off.....well I thought wrong. Opened the hood and replaced the fuse (it was fried).
Now the center channel thermal protect light stays illuminated, and still no output on this channel, all the other channels work.
What else can I check?
Sincerely, (ashamed and embarrassed )
G
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
i have a 7300 and 5300.
i would call Adcom or email them. They're customer service is regarded on these forums as pretty good.
good luck.
http://www.adcom.com/contactinfo.htm -
gwh, (just edited the name)
Adcom amps are built like tanks, and frankly one short like that shouldn't take out the output transistor. I know the 2 channel Adcoms have A.C. line fuses and D.C. rail fuses. The AC line fuse is accessible from outside the unit but the DC rail fuses are internal. Now I don't have any experience w/ the multi channel units so I can't say if there's more to look for. Have you checked the owners manual or checked the net, must be missing something. Again it would be very odd that one little short like would damage the outputs. But anything is possible :rolleyes:
Have you had a chance to call Adcom yet?
You can check the DIYAUDIO forum, but the threads can get a bit technical if you don't have a basic understanding of electrical circuits. Just do a search for Adcom. I did that recently but don't remember if your particular problem came up. Actually on that forum there are a lot of former Adcom techs who answer questions. Worth a try!
I opened it up again and peaked at the circuit board, didnt see any obvious signs of sizzle.
Guess Id better contact Adcom.
Thanks for the replies,
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Well no reply from Adcom, guys on the DIY forum seemed to think it needed surgery.
Anybody here repair Adcoms? Any of you Texas members know of a reliable competent repair tech somewhere just south of the Red River? Austin Texas looks like the closest authorized repair shop, really hate to tie $ up in shipping though.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
If you're like me you'd probably rather email than call, but the Adcom people are GREAT on the phone... Give them a call.
Also- the DC rail fuse is the most likely culprit- look for a fuse on the channel module that's dead- oh, and be very careful poking around in there- some of those cap's will stay charged for awhile.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
e-mail them dude.
They're no Outlaw or Polk Customer service- but you should get a reply within 3-5 days. -
Did you fix your center channel problem? Mind sharing the solution?
Thanks.
Nick -
Disconnect the thermal protection led from the board that says thermal overload protection. I learned this trick from an Adcom tech. No guaranties, but it is an easy "fix" sometimes. The channel is most likely not blown, and being the center channel it is highly unlikely to get over loaded like the mains would. If it works I would just run it;) Email me if you have further issues. I very rarely drop by here.
Ben -
This is a 7 year old thread Ben....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I replied to someone who posted yesterday.
Thanks John...
BTW welcome to
CP nick.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I called Adcom for an unrelated problem.They do not answer directly w/ a receptionist or menu .You leave your # and they do get back to you. I didn't like that system but the tec Dave did call back.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
