Think my mobo died? PS?
mdaudioguy
mdaudioguy Posts: 5,164
edited June 2012 in The Clubhouse
About a week ago, we were having a lot of power disruptions due to storms. Well, one time after the power went out for only a few seconds, I pushed the button to start my main PC and it starts to fire up like normal (even see some of the normal boot routine on the screen), then the screen goes black, flashing "no signal." Powered off and tried again - this time nothing on the screen. The CPU fan starts, I hear a single beep, like it's going to boot, then nothing. This every time now. Sound like the MB is shot? Or perhaps the PS? Not really sure how to troubleshoot either one...
Post edited by mdaudioguy on
  • mdaudioguy
    edited June 2012
    Thanks. I'll give that a try this evening. What is the point of it, though?
  • Syndil
    Syndil Posts: 1,582
    edited June 2012
    mdaudioguy wrote: »
    If you hear a single beep the mobo is fine. The problem therefore lies somewhere with the video. Either the graphics card is shot, or your monitor is shot. If you've got a spare one of either, that would be the easiest way to test.
    If a different monitor doesn't solve the problem, then it could be your graphics card. And if you graphics is integrated into your mobo, then yes, it does come back to being a bad mobo.
  • bansheesho
    bansheesho Posts: 227
    edited June 2012
    Also, I would give resetting the BIOS a shot. Generally you pull all the power and then yank the cmos battery (the watch battery) and move a jumper on the board to clear position (which one depends on your motherboard)... Then try again.
    This works sometimes, and its generally one of the steps to try and revive a system that isn't booting. I have had greater success with this if it won't post at all though
    The Idea behind yanking the cord and holding the power is to fully discharge all the capacitors... Which I have had some luck with as well..
    Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
  • mdaudioguy
    edited June 2012
    Figured I should UPDATE this - Tried ALL of the above advice (thanks guys!), but to no avail...
    Thinking it just had to be a bad power supply, I opened up another of my computers and swapped power supplies. The "suspect" PS powered up the other computer fine, while the other computer's PS fired up the "problem" computer just fine! :question::question::question::question::question:
    So, I put everything back where it started and EVERYTHING WORKS PERFECTLY NOW! I'm baffled, but at this point, with everything working, I'm like, why ask why?
    Anyhow, appreciate all the advice - I'm sure I'll be back for more down the road! :smile:
    edited June 2012
    Good news, maybe it wasn't your mobo but your mojo that you lost?
    cnh
  • Syndil
    Syndil Posts: 1,582
    edited June 2012
    Could have been a loose connector or a loose solder joint somewhere.
