Which A/V Receiver Under $1500 can Drive Polk RTi A9's so they Sound Good to Great!!!
AVTONY2510
AVTONY2510 Posts: 31
edited June 2012 in Electronics
JUST WONDERING IF THERE'S AN A/V RECEIVER NEW OR USED UNDER $1500.00 THAT CAN MAKE MY POLK RTi A9'S SOUND THE WAY THEY ARE SUPPOSE TO, BEFORE I GO & SPEND $2500.00 ON A PRE/PRO & AMP.
Current System:
Onkyo TX-NR708 Receiver
Fronts = Polk RTi A9
Center = CSi A6
Rears = FXi A4
Sub = (2) Velodyne FSX-12
YOUR SUGGESTIONS ARE GREATLY APPRECIATED...
Post edited by AVTONY2510 on
    edited June 2012
    I've found that Rti-A series sound best to "me" with a Marantz or a Denon AVR because they warm up the sound some? So anything in that price range that has pre-outs, because no receiver is going to properly power A9s!
    You should "listen" to both because your ears may not agree with "mine".
    cnh
  • B Run
    B Run Posts: 1,888
    edited June 2012
    I really like the SC series Pioneer Elite receivers, but since your 708 has pre outs you might consider just picking up an amp. You can get a hell of a nice amp for $1500.
  • chumlie
    chumlie Posts: 8,658
    edited June 2012
    Why not try adding an amp to your Onkyo first. Biased opinion, try Parasound.
    edited June 2012
    chumlie wrote: »
    Actually, this is not a bad idea. Parasounds tend to be "warmish".
    cnh
    txcoastal1 Posts: 13,519
    edited June 2012
    Couple options worth looking at:
    I know personally that the Pioneer SC-35 will run the gear listed great, I also ran my LSi's with it for a week while waiting on my amp
    http://www.amazon.com/Pioneer-SC-35-Elite-Receiver/dp/B004146438
    But if you want to go new this is a route thatt I would be happy with for future versatility...an amp for the RTi A9's let the receiver power the rest...nice 2chnl dedicated amp for stereo from a quality company and better resale value for future and be done till you get upgraditis
    http://www.wyred4sound.com/webapps/category/74030/117839/18047
    There are other manufactuer's and configs in this budget range....just my .02
    F1nut Posts: 51,997
    edited June 2012
    AVTONY2510 wrote: »
    Since you are new here, let me suggest you try some forum etiquette. Lose the caps and the blue text in the body of your post.
  • Conradicles
    Conradicles Posts: 6,376
    edited June 2012
    Wow F1 why would you say that?
    F1nut Posts: 51,997
    edited June 2012
    I'm sure that if you think about it long enough, you will figure it out.
  • Conradicles
    edited June 2012
    I DID AND STILL CAN'T FIGURE IT OUT...:cheesygrin:
  • DarkHorror
    DarkHorror Posts: 73
    edited June 2012
    I would suggest something with high quality room correction, like the Denon 4311 which has Audyssey XT32, Sherwood R972 with Trinnov, and Anthem with ARC. All have pre-outs so you can add external amps if you want more power. Plus can be found for much cheaper than you are looking to spend. I would read up on the different room correction, and see which one sounds the best, give them a try in your home if you can.
    nooshinjohn Posts: 26,000
    edited June 2012
    BECAUSE LARGE RED LETTERS ARE BETTER!:razz:
    F1nut Posts: 51,997
    edited June 2012
    Effers
    edited June 2012
    Effers
    What I can't hear you...LOL
    edited June 2012
    Effers
    I love that! LMAO!:cheesygrin:
    Back to the thread... I agree with those suggesting that you get a good amp to drive the fronts rather than just going separates. My system has two tube amps anchoring my mains and a 7 channel 400wpc Sunfire driving the rest. This power is being controlled by a Pioneer SC-37, and will soon be augmented with an HT bypass capable two channel preamp.
    The next thing I need is a house to stuff all that good stuff into.:wink:
  • AVTONY2510
    edited June 2012
    How would an Emotiva XPA-2 Amp. Sound with a Pair of Polk RTi A9's?
    Any other Amp. Recommendations would be Greatly Appreciated...
    edited June 2012
    AVTONY2510 wrote: »
    Search the forum under Emotiva
    Or amp suggestions....tons of threads and arguments
    edited June 2012
    AVTONY2510 wrote: »
    It is my understanding that the words "bright" and "fatiguing" come up quite often The A9's tend towards bing bright already do to the HT nature of their desighn, and Emotiva is a very forward sounding amp. The two together would not make a great pairing IMHO.
  • pietro944
    pietro944 Posts: 720
    edited June 2012
    The all caps are considered .by some,to be shouting......However,the dark blue text in italics is excellent...Very readable and more conversational...I'm going to start using it:wink:
  • brunk
    brunk Posts: 11
    edited June 2012
    Emotiva UMC-1 Receiver $500
    Emotiva XPA-5 Amp $900
    Total= $1,400
    Be done with it and enjoy
    AVTONY2510 wrote: »
    Current System:
    Center = CSi A6
    Rears = FXi A4
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited June 2012
    Chumlie has a good suggustion. Never heard a avr that i thought sounded good (at least for music) seporates will do much better amd offer u more future options.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • jbooker82
    jbooker82 Posts: 1,627
    edited June 2012
    I would spend the cash on a good used "warm" amp. Something like a parasound or.carver.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2012
    AVTONY has 12 threads out of his 26 posts. He is asking the same question in multiple threads he has started. I think he is not taking previous advice and recommendations seriously. He probably has blue audio gear in rack already as every post he makes has been that color
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited June 2012
    AVTONY2510 wrote: »
    Personally, a similar combo for me (XPA-2 and XPA-3 with my RTi system) was just ok... nothing to write home about. Replaced both Emo amps with a 5-channel Adcom and haven't looked back. And while my inital motivation in buying Emo was cost (unfortunately, I didn't consider used at that time), the Adcom solution saved me money, and improved sound quality (win-win). Look around and be patient - the kinds of people who usually buy "better" gear (think Adcom, Rotel, B&K, Parasound, etc...) usually take exceptional care of their gear. When I picked up my "used" amp, it had not a scratch on it, and has performed marvelously since then.
