Music Fidelity KW SACD player...
Toolfan66
I just received this unit and have been playing a few red book CD's and a few SACD's
My only issue so far is getting the player to play Hybrid SACD's in SACD mode, it will pick up that it's playing a standard SACD but not a Hybrid SACD..
Thoughts??
On another note I have read good and bad reveiws of this player, this unit is built like a tank and has none of the issues that I have read in some of the bad reveiws noisy transport one guy states his is a $7000 door stop:eek:
Like I said I don't hear any noise or see any flaws except the Hybrid SACD reading..
Thoughts??
Post edited by Toolfan66 on
Larry, is there a way to choose either standard CD or SACD with a button on the player face or remote? My Denon DVD-5910 allows you to choose which layer you want to play on hybrid SACD's. You may need to set the player to default to the SACD layer when using a hybrid disc. Other than that, I am not sure.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I believe F1 is the expert on this bad boy IIRC.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Nope, there is no button to choose from, my Sony has that option.. -
Doing a google search I found this.
"The only other glitch with mine (which I've learned to live with) is that when just switched on it is reluctant to recognise the SACD layer of hybrid discs. However when fully warmed up (the legs start red, go orange and then turn blue when the valves are appropriately cooking!) this problem diappears. "
http://www.sa-cd.net/showthread/39348/50180Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Is there anything in the Menu or setup?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
No menu, and the legs do start red then orange then blue.. I just switched it to tube valves..
Larry, try the hybrid SACD when the legs are blue and see if it works. According to the SA-CD.net link BlueFox provided that should solve the problem. I hope it does for you, otherwise hopefully Jesse can help when he returns. What's he doing anyway?
I have her warming up now to give that a try..
Just for the record this unit sounds amazing better then anything I have owned to date..
