Polk Audio RTi A9'S Does Polk Recommend Bi-Wiring or Bi-Amping?
AVTONY2510
Also how many Watts Per. Channel Amplifier does Polk Audio Recommend
for Maximum Performance?
Post edited by AVTONY2510 on
500 watts is preferred..
As far as biwire/biamp, etc - preference...
Realistically bi-wiring versus a single wire with upgraded jumpers is negligible differences. Personally for I like having a dedicated wire run (although it connects to the same place on the amp) for each hook up.
Technically bi-amping is useless unless you are filtering the signal before it gets to the amplifier... otherwise the amplifier is still amplifying a 20-20 signal versus a limited frequency signal.
My suggestion is try to seek out a nice high current clean amplifier... somewhere from 100-500 watts and have at it!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
HEY VR3, so are you saying just hook them up the regular way with the jumpers on?
Sure, I would replace the jumpers with a heavy guage wire though- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Signal ultra bi-wire speaker cables are a great option at a very good price.
If you want those A9's to sing, look for a good high current amp in the 200-500wpc range. I'm a huge fan of Parasound myself. -
I like Single Bi Wire cables as well. Single Bi Wire cables have one set of bananas on the amp / reciever end and 2 sets of bananas on the speaker end. You then remove the jumpers and plug all 4 in to the speaker.
I use Audio Quest Type 8 single bi wires.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Heck yeah to the bi-wire AND upgraded jumper. I'm using both, here's a couple of examples.
Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
Where can i purchase signal ultra bi-wire cables?
AVTONY2510 wrote: »Where can i purchase signal ultra bi-wire cables?
http://signalcable.com/products.html
If you mention you're a club Polk member you get a bit of a discount as well.
