Dial Norm?
deronb1
Often, especially when playing a BluRay, a message will appear in the window of my Pio AVR that says "dial norm -3" or some other number, usually -2 to -4. What does that mean?
Post edited by deronb1 on
The "-3 " means your down 3 beers for that point in the movie.:cheesygrin:
Honestly, I don't know, never saw that before on my Pioneer. Sorry I can't help ya bro, maybe someone will chime in with an answer. I'm guessing maybe it's telling you your down x db's from reference ? But then, why would it do that ?HT SYSTEM-
lsi 9's -
When properly calibrated, you should be around 0."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yeah even when selecting just TV programming I would see the same thing. I just ignored it.
I always did my MCACC calibrations but the number never came close to "0". -
3 beers..lolo..The "-3 " means your down 3 beers for that point in the movie.:cheesygrin:
Honestly, I don't know, never saw that before on my Pioneer. Sorry I can't help ya bro, maybe someone will chime in with an answer. I'm guessing maybe it's telling you your down x db's from reference ? But then, why would it do that ? -
Dialnorm is an attempt to make it so that loudness (not just VU or peaks) is taken into account and a playback of different sources can automatically compensate for overall loudness differences and playback without big differences. The idea is that by playing back through a metering system, they can establish the content loudness and establish how loud it should be to fit in with other material.
When you see a -3, I don't know off hand if that means you should attenuate by 3db or if the material is 3db lower than the establish norm and needs turned up by 3db.
I didn't know that this was ever showing up in consumer equipment actually. Dialnorm is I think the big culprit behind the level problems in HD television since the conversion to HDTV. It was suppose to make everything easier and seems instead to have resulted in all kinds of confusion and level problems. Such that congress has even passed a law to save us from levels not matching. The biggest problem has always been cable systems inserting their own commercials and some tech not bothering to even attempt to set levels. Dialnorm is supposed to do that automatically and not rely on the underpaid, untrained tech to do it.
CJA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
From what I have read you just leave it alone. It's a Dolby thing.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Call the New Yankee Workshop for AV built-in shelving services, ask for Norm.
Dialog normalization is a setting that is set by the sound editor when they are mixing. It is not something that you can change or turn off.. if you Google it you will find some very detailed info on it on how the engineer is suposed to calculate it and the differences between dts and dolby calculations..Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
Good stuff guys. Thanks.
