What's this and why does it get so hot? Vintage Marantz related
jemrey81
Hey guys, can you tell me what this is and if it's supposed to heat up? It starts getting hot as soon as the unit is turned on. Sorry, I should have circled the thing in the picture... its the gray thing (easier to see in the second photo) that has 3W150 on it (upside down).
thanks :redface:
thanks :redface:
Post edited by jemrey81 on
Looks like a heavy duty 150 ohm resistor that can handle 3 watts. It is supposed to get hot. Need a schematic to see what it is actually doing.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
It's a 150 ohm, 3 watt resistor. They chose 3W there for some reason -- obviously they knew it would have to dissipate some heat, and that's why it gets warm.
Judging from the pics, looks like it's in the power supply. -
Hello,
That is a 3 Watt, 150 Ohm resistor. Do you happen to have a DC Volt meter? If so, with the unit turned off put one of the meter's clip leads on each end of the resistor, that way you can determine the voltage drop across it (once the unit is turned back on). Once you have that number, square it and divide by the resistor value.
Regards, Ken -
Ok cool.... I was just going through it and cleaning out all the years of dust and was checking everything out while it was on. I guess I just need to put some bulbs in and she'll be ready to go.
Thanks guys
Kenneth Swauger wrote: »Hello,
Regards, Ken
Thanks for that info... I'll check that out! -
Kenneth Swauger wrote: »Once you've made that measurement multiply that times the resistance value (150 Ohms) and see if it exceeds 3 Watts.
Regards, Ken
Well, not exactly... Power = (Voltage squared) / Resistance.
Ack, my mistake -- are both correct? -
P = I^2*R
Ken's right. -
I saw my mistake as soon as I posted it, what I gave was the current flow, not power. That number would then have to be multiplied times the voltage drop for power.
