hdcd vs cd
soundfreak1
soundfreak1 Posts: 3,414
edited June 2012 in Music & Movies
My dac is capable of hdcd conversion.(adcom gda 700) is there a diff. In sound quality? And is it worth the price?( i assume there is a price diff.) worth checking out?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
    heiney9 Posts: 25,402
    edited May 2012
    You have to play HDCD encoded material. There are only a handful compared to regular redbook.
    http://en.wikipedia.org/wiki/High_Definition_Compatible_Digital
    http://www.goodwinshighend.com/hdcd.htm
    Is it worth the extra cost vs. a std redbook? The price shouldn't be that far off. I would never pay extra for an HDCD unless it was a very rare cd in and of itself.
    edited May 2012
    Somewhere around here I have an old Panasonic/Technics CD changer that can do HDCD. Can't say I've heard much of a difference on it. But then again this is not your high end player!
    cnh
  • Conradicles
    Conradicles Posts: 6,325
    edited May 2012
    I have quite a few HDCD's and love the way they sound on my NAD CD player. I can notice an improvement over a redbook CD.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited May 2012
    I have about 10 hdcd's and they all sound excellent. There is a recording label that predominately produces HDCD's and it's called Reference Recordings. Check it out. They mostly do classical and jazz.
  • soundfreak1
    edited May 2012
    Im a jazzman. Mostly accoustic jazz. I will ck them out thanks. My cdp is not hdcp just the dac. Will the dac do the decoding. By itself?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    edited May 2012
    Yes, because you will just be using your cdp as the transport. The 700 will be doing the digital decoding and analog conversion.
    If I might make a suggestion to use the Coax connection between the cdp and dac and get a decent 75 ohm cable like this one *here* - Belden 1694A
  • FTGV
    FTGV Posts: 3,650
    edited May 2012
    The few HDCD releases in my collection are mostly mid 90's of the C&W genre and where IIRC priced on par with standard redbook.I guess Nashville studios where early adopters of the format but it did'nt seem to get the overall market penetration that the developers had hoped.Your 700 has a special digital filter IC that also functions as the HDCD decoder.Infact I believe the developers suggested that even redbook benifitted from the use of their digital filter.
  • soundfreak1
    edited May 2012
    H9, i did an a/b conpairison and couldnt "hear" any diff. Between the opt. And the coax cable. but thats just my ears.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited May 2012
    Ftgv, on the 700 the hdcd decoding is not manual it must detect a hdcd format to decode or it not activated ( so i believe, as there is smiply a led to indicate a hdcd signal is being recieved and decoded.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • FTGV
    FTGV Posts: 3,650
    edited May 2012
    Yes,if the HDCD decoder/digital filter IC picks up the HDCD flag it will automatically decode it.Standard redbook data will be processed by the same digital filter IC even though it does not have the imbedded HDCD data.
  • soundfreak1
    edited May 2012
    i will just have to find a hdcd cd and try it amd see if i can hear a diff. Im also a alan parson fan so i'll try to find one of those to a/b. Hopefully he did some in hdcd.he did some fantastic studio work on his music as well as for the Beatles and pink floyd just to mention a few.will report back on. The comparison.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • FTGV
    FTGV Posts: 3,650
    edited May 2012
    Personally I think the sonic benifits of HDCD were overstated and a good sounding one was the result of good recording/engineering /mastering and would have sounded great even on standard redbook.My experience has been that well recorded HDCD's played via non HDCD decoding DAC's still can sound very good,the result of good recording practices in the first place.
  • Conradicles
    edited May 2012
    FTGV wrote: »
    Very well said.
  • FTGV
    FTGV Posts: 3,650
    edited May 2012
    To add to that I suspect if a studio is/was willing to spend the money to adopt the HDCD format to begin with they obviously take their kraft seriously and sound quality can be assumed to be high on the priority list.
  • skrol
    skrol Posts: 3,437
    edited May 2012
    I have found that the HDCD's tend to sound very good even on standard CD players. I figured that HDCD was trying to make a go of it and more was put into the mastering to make it shine. I believe that they do sound a little better on a HDCD decoder but I have no way of doing an A/B comparison.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited June 2012
    Just like regular Cd's some sound better than others.
    I have a Rotel CDP that plays HDCD and some sound great. I don't believe that you can buy the CD with or without having it in HDCD format. It's either HDCD or it isn't.
    I always think they sound much better IMO.
