D-Sonic & Wyred 4 Sound amps.
pearsall001
Thoughts, pro/cons...any 1st hand experience on their performance. Inquiring mind wants to know. Thanks
Post edited by pearsall001 on
No experience with D-Sonic, but have owned just about every W4S product.
Never had an issue with any of their products. As for SQ, clean and transparent without being harsh or thin. Huge dynamics and the lowest noise floor I've experienced."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Are you currently using either brand in your rig? -
He has been a W4S fan for a few years now, and for good reason they build some killer gear, I have yet to try one of there amps.. -
I'm using a W4S ST-1000 amp for my 2-channel setup. Very warm tone, highly detailed, not that far away from Parasound sig. I definitely recommend this brand.Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
Currently using 8 W4S products in my rigs.Are you currently using either brand in your rig?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I have experience with D-Sonic and will say they are great amps. Very good customer service and the product performs very well. Highly recommended.Shoot the jumper.....................BALLIN.............!!!!!
No experience with the D-Sonic amp,but have had the pleasure to have met Dennis a couple of times and firmly believe he stays on the cutting edge of audio technology and goes above and beyond to build only the finest equipment.I have heard nothing but praise from a few other folks who have some of his products.
