TL 150 wall bracket screw
inner
Hi,
I woluld like to build my own wall bracket for my new TL150 speakers. I dont want to use the key holes. So I decided to use the .25 x 20 threaded insert. Can you tell me that what kind of screw do I need. Is it a metirc (M6) or something different?
Thank you in advance!
Post edited by inner on
Hello,
The bolt should be 1/4" diameter with a #20 thread.
Regards, Ken -
I smell
