Advise on powering fronts (L,C,R)
jemrey81
Hey Guys,
I currently have an older (pre hdmi at least) Pioneer receiver (closer to entry level) that has been pulling HT/ Stereo duty for a few years now... it's been running a pair of TSi100's (L&R front) and a CS10 (obviously the C) and I also have a PSW505 sub (no rears).... it hasn't been too bad, but I just changed things up speaker-wise :eek: I sold my TSi100's and bought a pair of Monitor 70's.... with very little out of pocket
I know the M70's are probably going to overtake the CS10, but that will most likely get switched over before too long.
So I have started looking around at other options that "could" be available for power and am starting to get a little lost :frown:
What are the best options for a 3.1 setup? I do listen to A LOT of music (it's on most of the time I am home), and I usually have the receiver and speakers going if the TV is on (whether its a movie or cable). Are there any 3 channel amps for the fronts like this or is it mainly 2 or 1 channel? Are there any budget friendly receivers that you could recommend for powering these decently? I don't plan on going 5.1 or 7.1 anytime soon (I would have to move first, and that's not happening for a while).
Thanks for any help or tips you can provide!
Oh, and while I am here.... Should I get a CS2 or is there something better I should look for (more fitting to the M70's)?
Post edited by jemrey81 on
See how you like the 70's with the CS10, but yes the CS2 is the correct match. IMO don't even think about the CS1 to pair with them.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
You might enjoy just going with a 2.1 system for now. Then you have good 2 channel preamp/amp, or integrated amp options that are much cheaper for great quality than you were to find on full featured 5.1 receiver. What features and inputs do you need the new receiver to have?
Hmm, I haven't tried it in 2.1 - that might be a good option. Is there a way to test that with my current receiver before I jump into that?
I would like to have hdmi in and out.... not sure about anything else. I know I won't ever need 3D...
What other options are there to consider? -
Yeah just go into the receiver settings and turn the center to off. If there is no option for that see if there is a stereo setting on your receiver that should mean the center isn't working. It might be the default for music anyway, when you are listening just go up to the center speaker and see if any sound is coming out of it.
Turn your listening mode on the pioneer to stereo. That will turn off the center. I would still keep it 3 channel. That way you have some sort of audio for tv and movies.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
DarkHorror wrote: »Yeah just go into the receiver settings and turn the center to off. If there is no option for that see if there is a stereo setting on your receiver that should mean the center isn't working. It might be the default for music anyway, when you are listening just go up to the center speaker and see if any sound is coming out of it.
Got it... It has both options. I listen to music in the stereo mode. I know that I don't like that for TV and movies though.... does it sound different if I turn the center to "off" then mess around with all of the sound settings? I have seen people mention the phantom center or ghost center... something like that
I use my two channel for watching tv occasionally, and I don't really like it either, but since it's primary function is music, I get by. DarkHorror had a good suggestion, but IMO if you watch a fair amount of movies/tv I would get the center.
I would look for a good quality 5.1 receiver on the used market. I see a fair amount of them on CL. Pioneer/Onkyo/Harman Kardon is a good place to start for budget used that should pair well with the Monitors. I've only heard the HK, but see good reviews on the Pio and Onk.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Thanks guys... is there anything I should be looking for in the different brands (HK, Onk, Denon, Pio) - like wattage / power ratings? I don't trust what they say on the boxes.
I wonder if I could find a local audio / video nut to trade a nice receiver for some MIT cables.... -
I would just get something good enough to come with amplifier pre outs. That way later on you have the option to add an external amp. For onkyo you would need a TX-NR7xx or higher. The last number is for the year. The current models end in 9's. The 9's have a better / newer Audyssey MultiEq XT automatic calibration where last years 8's just have MultiEq 2.
You can save a pretty good chunk of change by going with a refurbished one from accessories 4 less. You can also add on a 5 year warrenty for $50.AVR: Onkyo Tx-NR808
Rear: FXI A4
