Tube amp questions
newbie308
newbie308 Posts: 800
edited May 2012 in 2 Channel Audio
I started putting together my audio system about three years ago, and I have benefitted greatly from reading the posts of other forum members. The primary sound source is a Technics sl-1200 turntable with a Grado cartridge. I enjoy undertaking new projects, so many of the items in my meager system were DIY rebuilds (Dynaco PAS-3, SDA-1a). The only component in my system that I simply purchased and pluged in was the amplifier (Carver TFM-35). I have no reason to dislike the Carver amp, but I am curious about tube power amps, and I can no longer contain my desire to go all tubes. I noticed an immediate improvement when I replaced the Adcom preamp with the DIY rebuilt Dynaco, and I can't help but wonder how my system will sound if I go with a tube amp. Maybe a DIY project or kit?
All that being said, I don't know how many Watts I'd need to drive the SDA-1A's efficiently with a tube amp (the Carver is rated at 250 Watts per channel into 8 Ohms). From what I have been reading, many tube amps are rated at 12-35 Watts per channel, and cost $400-$600, and then there are some 100 Watt mono block amps that cost $900-$1500 each which I probably don't need, but definitely lust for. I know that whatever I buy will need to be common grounded for the SDA's, so does that exclude mono block amps? Can The monoblock amps grounds be bonded to achieve a common ground? Where do I begin? Please help!
Post edited by newbie308 on
  • organ
    organ Posts: 4,969
    edited May 2012
    I don't have experience with the SDA so I can't help you there, but since you're looking for a kit/DIY, you can have a look here.... http://dynakitparts.com/store/catalog.aspx?cid=1 and here... http://bottlehead.com/ BUT someone else would have to confirm if the units on those websites are common ground or not.
    heiney9 Posts: 25,398
    edited May 2012
    One thing to keep in mind is the higher power tube amps put off a fair amount of heat so if you end up going the mono-block tube route be prepared to abate the heat, unless you have an unusually large room. Just something to keep in mind as most people don't realize how much heat 4-6-8-12 power tubes actually produce.
    My solid state amp can heat my living room area up 3-4*, in the winter not bad, in the summer the difference between 75* and 79* is quite noticable. 75* with a decent breeze may not need the air on. 79*, probably turn the air on.
  • Jim Shearer
    Jim Shearer Posts: 369
    edited May 2012
    organ wrote: »
    I recently built a Dynakitparts.com ST-35. Don't know about the others, but the ST-35 is common ground.
    And I can recommend dynakitparts for their excellent customer service. Kevin returned my emails very quickly--even after business hours.
    Cheers, Jim
    A day without music is like a day without food.
