Projector question
jon1redleg
Hey I am looking to set up an outdoor system to watch movies on. I was thinking of putting everything in a portable
cabinet so i can move in and out of house or shed. I have an old Kenwood av amp, old RCA suround sound speaker
system and old DVD player. This thing isn't going to be pretty but effective to watch movies on when the wife, kids and I are outside on patio by fire so I am looking for a fairly cheap projector.
I'll probable spend more than it's worth but wife came up with idea and I thought why not. I was looking at EPSON
because thats the brand I am used to seeing, what ya guys think?
Post edited by jon1redleg on
Epson is popular because they have a few that are highly rated but generally win in the cheaper department. They also lean toward very bright as in more lumens. The idea sounds good but need to decide what you are going to project on. If it's outside you might consider painting a screen. I personally have zero experience with this but have heard it done.
https://www.diytheatre.com/shop/shopdisplayproducts.asp?id=13&cat=Screen+Product
I have shopped at Projector Central before. If you are looking for a cheap projector they have a great variety of used projectors from sellers across the United States. They also have a terrific review page so it's a great place to start. One seller has a used Epson 720 for a couple hundred bucks right now which is a good deal. That's a very popular projector if you don't want to spend a lot of cash. That's probably the way to go if it were me- you can abuse it for a few years and replace.
http://www.projectorcentral.com/used_projectors_details.cfm?classified_id=20433
If you don't want a used one you can check out the Optoma HD66 which is a bit brighter but more expensive.
http://www.projectorcentral.com/Optoma-HD66.htm
I hope that helps and best of luck.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Agree with hockeyboy. Paint a screen using Goo or making one will be the easy and cheap way to go about it. As for projector and since it's outdoors you may consider something from Benq since they get plenty bright. The good thing about buying a projector is buying one you can use indoors. Once the wife sees a good picture, you'll want one indoors for sure.
Here are a few projectors that should be great outdoors.
http://www.projectorpeople.com/projectors/projdtls-v2.asp?itemid=26560
http://www.projectorpeople.com/projectors/blowout.asp
Outdoor screen this cheap, just buy it.
http://www.projectorpeople.com/screens/proddtls.asp?productid=27158Shoot the jumper.....................BALLIN.............!!!!!
