Would this sub work for LSi15 mod?
hochpt21
hochpt21 Posts: 5,423
edited May 2012 in Speakers
Polk Audio MM840
Mobile Monitor Series 8" subwoofer
Specs here...
http://www.crutchfield.com/p_107MM840/Polk-Audio-MM840.html?tp=972
I am considering doing the mod with the db840's, but then I saw this and wondered if the mm's could even be better than what people are reporting with the db's.
I don't know if they are compatible or even fit, but the specs looked a little 'stronger' so I just thought I'd ask.
Post edited by hochpt21 on
    EndersShadow Posts: 17,722
    edited May 2012
    Someone used one of them for their lsis and liked it. Personally since the Polk engineers suggested the db840 sub I went with their recommendation :smile: plus it's cheaper :biggrin:
  • Face
    Face Posts: 14,340
    edited May 2012
    Sealed Box Volume: Polk recommends using this woofer in a sealed enclosure; the ideal internal volume is 0.35 cubic feet.
    With a QTS of .6, I would not recommend using it in a ported enclosure.
  • hochpt21
    edited May 2012
    Sounds good. I am ever so close to pulling the trigger on the db's, but just wanted to check before doing so.
