Reciever recommendations under $1000
jarod
jarod Posts: 21
edited May 2012 in Electronics
hey guys i have spoken with some of you on my other posts on my setup but i will be moving this weekend and i may look at a new or even used reciever this weekend. What would be some that you all would recommend? I would really love to find a smokin deal on e-bay or amazon on something used or discounted since the one i have is barely a year old. that would take the sting out of the expense.:eek: Wether new or used i would like like a 7.1 with i-pod integration and thats about all i require so i am pretty open. Thanks in advance for the help.:razz: TSI 300's front-CSi10 center-TSI 100's rear surround and a 10" KLH powered sub is what i currently have but that is subject to change after i get moved in if i cant get the sound i am after.
Post edited by jarod on
    EndersShadow Posts: 17,687
    edited May 2012
    jarod wrote: »
    Onkyo TX-NR809 from Accessories4less. Its an authorized reseller of Factory refurbished units. You still get a 1 year warranty as well. If the 809's power is a bit much for you, its smaller brother the 709 can be had for under 450 and just doesnt have as much power.
    Either one of those will drive your speakers fine and they both have pre-outs incase you want to add a dedicated amp later on.
    You might be able to find deals on New 809 or 709's but not for much longer as the 818 is coming out and its going to kill both those models since it has a better EQ (Audyssey XT 32 v. their XT version).
  • newrival
    newrival Posts: 2,017
    edited May 2012
    edited May 2012
    All of the above receivers are "great" choices but not all of them can handle ipod interfaces? Anthem is a nice sounding piece but something like an Onkyo has so many more features it's not even fair to compare the two even though the Anthem will have the better sound for music.
    Elite, also a good choice. Heck, they're all good.
    Have fun. Any of these receivers have "more" than enough power for your current speaker set and give you room to upgrade in the future. The first thing I would do is dump that KLH sub!
    cnh
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2012
  • Syndil
    Syndil Posts: 1,582
    edited May 2012
    Marantz AV5006 or Integra DHC-40.2 w/ a separate amp.
  • jarod
    jarod Posts: 21
    edited May 2012
    hey guys thanks for all the fine examples to look at. I am going to try and have everything up and running by saturday and after i watch some movies on it and play some music i will make a decision on a new reciever. I will let you all know how it pans out.
