Squeezebox Touch Experts-Help me out here
CSM41
I have a Squeezebox Touch hooked up with my Simaudio DAC via a coaxial cable. The SBT is hooked into my wireless router via cat5 and the router itself is hooked into my laptop via cat5. Now here is my problem. When I play a 24/192 .flac file the DAC only sees a 24/96 bitrate. I know the DAC isn't the problem because it switches well between other sampling rates. Does it not see 24/192 due to the cat5 connection between my router and laptop, or does the SBT not support 24/192 files? Or, is it a problem somewhere with the Windows 7 operating system? Any input is appreciated. See sig for my gear used.
#1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
#2 Cayin A-50T /Hornshoppe Horns/Squeeze Box Touch/Simaudio Moon 100D DAC/Rythmic F12 Servo Sub
Post edited by CSM41 on
Windows 7 has nothing to do with running the SQB. The SQB software runs the SQB. I would go to the Logitech SQB forums and see if other have this issue. If I had to make an educated guess without doing any research, perhaps the SQB or the SQB software only supports 24/96 bitrate and won't pass anything higher. You'll have to get your search on.
Where did you get a 24/192 FLAC file?"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
That was one of my thoughts also. I have bought all of my 24/192 albums from HD Tracks.#1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
#2 Cayin A-50T /Hornshoppe Horns/Squeeze Box Touch/Simaudio Moon 100D DAC/Rythmic F12 Servo Sub -
Are you 100% sure they are actually 24/192? HD Tracks has been known to "overstate" some of their specifications. You really should go over the BB at SQB forums I'm sure this has come up before.
It's funny you mention that. I have read the same thing about HD Tracks myself. Squeezebox shows them as 24/192, but I believe that is due to how they are tagged.#1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
SB Touch only supports 24/96 max.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Even with an external DAC that supports up to 24/192?#1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
yes, even with the external DAC b/c the touch stock, can't send it digitally at 24/192.. however Audiostream.com http://www.audiostream.com/content/get-usb-dac-and-24196-digital-output-your-squeezebox-touch made mention of a new app for the Touch that adds USB out functionality as well well as giving it 24/192, now i haven't tried the third party app, but its going to be the only way for it to send a 24/192 file.Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
OK, Got it. A fellow on the SBT Forum set me up with a file app that will allow the 24/192 files. Thanks, guys!#1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
What app is that?2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Cool...installed.....thanks!2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
