DIY sub ... Just as expensive as buying new!
I posted this on the AVS Forum, but thought I might get your opinion here on Polk ...
I was looking into purchasing a powered sub for my 2-channel audio only home setup. There are some very good powered 12" subs in the $500-$600 range:
Epik Legend .............$ 499
HSU VTF-2 mk4..-.....$ 519
Outlaw LFM-1 Plus.....$ 499
Rhythmik FV-12........$ 549
SVS SB-12......-........$ 599
So, I thought, I wonder if I could build a DIY sub myself that would be somewhat equal to these subs I list above. And at the same time, I could save some money by putting it together myself. I would be looking for a good quality 12" driver, an amp in the 250 w RMS range, and a box of 3.0 cu. ft interior size.
I would need to find a box that has the panels pre-cut to size already, since I don't have any woodworking power tools.
So I picked parts from the Parts Express website (these are all Dayton Audio parts):
Cabinet
Model #: SWC3-CH
Type Enclosure: Construct as a Sealed Unit
Internal Volume: 85 Liters (3.0 cu. ft)
Finish: Cherry Veneer
Dimensions: 19" x 19" x 18"
Weight: 52 Lb.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=302-845
Price: $ 234
Ampifier
Model #: SPA250
Type: Mono, Class AB
Power: 250 w RMS
Damping Factor: 114 @ 100 Hz
Signal / Noise Ratio: 110 dB
Adjustable Low-Pass Filter: 40 Hz - 180 Hz
Phase Select: 0 - 180?
Adjustable Gain
Weight: 13 Lb.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-803
Price: $ 120
Sub Driver
Series: Reference HF
Model #: RSS315HF-8
Cone Size: 12?
Nominal Impedance: 8 ohms
Freq. Range: 25 - 1,500 Hz
Sensitivity: 85 dB
Vas: 2.70 cu. ft
Qms: 2.94
Qts: 0.53
Lightweight Anodized Aluminum Cone for Rigidity and Lower Moving Mass
Triple Shorting Ring Motor for Ultra-Low Distortion
Weight: 25 Lb.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-445
Price: $ 149
TOTAL PRICE: $ 503
________________________________
Well, so much for putting this together myself and saving any money. The price would be basically the same as buying a new Epik Legend with dual side-firing 12" drivers for $499. http://www.epiksubwoofers.com/legend.html
And now I am wondering if my home-brew "Dayton" sub would have the same quality of sound of the Epik Legend, or any of the other subs I listed above?
Don't seem to be much of a bargain (or a good idea) to me anymore. Just wondering how any of you folks feel about this?
Ron,
Cabinet
Model #: SWC3-CH
Weight: 52 Lb.
Price: $ 234
Ampifier
Model #: SPA250
Power: 250 w RMS
Adjustable Gain
Weight: 13 Lb.
Price: $ 120
Sub Driver
Model #: RSS315HF-8
Cone Size: 12?
Sensitivity: 85 dB
Vas: 2.70 cu. ft
Qms: 2.94
Qts: 0.53
Weight: 25 Lb.
Price: $ 149
TOTAL PRICE: $ 503
Ron,
2-Channel Audio
Onkyo ... A-9050 . . .Integrated Amp. (Power Amp Section not Used)
Onkyo ... M-282 . ... Power Amps .(Pair)
Onkyo ... C-7030 . _.CD Player
Polk . . *. RTi A7 - ....Front Speakers
Polk . . *. RTi A3 - ....Rear Speakers
Post edited by Turbota on
Now a DIY in the $1000 - $1500 range would be sweet IMHO.
But, as in the example above ... I would pay just as much as a brand new Legend, and I might not even get as good of sounding sub with my "homebrew" selection of parts.
I just used the Legend as an example. I am not committed to that sub. There are other great subs in the $500-$600 range as shown in the subs brands I posted above (and there are many more I did not include).
It can definitely be cheaper but you have to compare apples to apples. You're comparing a DIY to manufactured subs that have different components and construction. Take, for example, the Ryhtmik F15, you can buy it for around $1100, or you can buy the servo amp/driver DS1505 kit and free plans for ~$630 and spend $200 on cabinet and finishings and be ahead nearly $300. They also have a 12" version that will bring you in near the $500 mark and still save you ~$175 from buying complete.
Also look at the Parts express Dayton Titanic kits. They save you a good amount of coin just for assembling it yourself.
http://velodyne.com/subwoofers/shop-all-subwoofers-1.html
http://www.polkaudio.com/forums/showthread.php?119747-DIY-dual-Dayton-10-quot-sealed-subs-piano-black&highlight=dayton+diy+subwoofer
Game Room HT: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology SM450; Definitive Technology LCR2000; Definitive Technology StudioMonitor350; Mirage Nanasats; Sub - HSU VTF-2 MK5
Master Bedroom
Cambridge Azur 551r; Definitive Technology promonitor 800; ACI Titan Subwoofer
I've got an HSU STF-2 currently and will be looking at an HSU or Epik sub next for about $500. I don't need the bass a $1K sub would provide, and I couldn't build it for cheaper than $500 as the parent pointed out.
Some people love DIY projects, have the tools, the time, and may have done the necessary research already. That's wonderful for them, just not for me.
12" Subwoofer
THRUSTER Series II Model THW 1260
4 Ohms 200 Watt RMS
2" Voice Coil 50 Oz Magnet
Recommended Box Size Box Size Ported 2.2 Cu ft
2 Ports 2 3/4"Dia X 2 1/4" Long
Fs 30Hz
Freq Res 25Hz-2K Hz Box Size Sealed 0.7 Cu Ft
SPL 90Db
QTS .21
VAS 395L
PRICE 39.95 each
The last part here is the key. What the op is suggesting is barely DIY. Assembling an essentially ready made kit isn't going to save you much. But if you have tools and time - the two main ingredients - you can save some cash.
Master Bedroom
Also, in these price comparisons, all of the premade subs are made of cheap looking black vynil. The DIY one looks much nicer
The guy that made that post did really a fantastic job on that pair of subs.
I am no speaker builder expert, but I do have some experiance in paint finishing. I would have done it just the way it's done on a car ... After primer and wet sanding, I would use a 2-part paint system ... That is maybe 2 coats of gloss black folowed by at least 4 or 5 coats of clearcoat. Then wetsand and machine buff with a rotary polisher. You get a gloss finish just like on a new car.
But, from what I could see in the photos, his way of applying the finish did work out nice too.
If I have my car subwoofer, can I buy one of these amps and make a little separate box for the amp and use it to drive the sub?
This sub actually has dual 4 ohm voice coils that are wired in paralel, but I can rewire them in sequence to the total load is 8 ohm..
By the way, it is for sale, pm me if interested
Tony
Outlaw Audio 976 Pre/Pro
Samsung BDP, Dish Rcvr, Xbox, Phillips CD chgr
Canare 14 ga - LCR tweeters inside*; CC outside
BJC 10 ga - LCR mids, inside* & out
8 ga Powerline - LR woofers, inside* & out
*soldered
LR: tri-amped RTi A7 w/Rotels. Woofers - 980BX; M&T - 981
CC: Rotel RB985 -> tri-amped CSi A6
5 Audio Pro Subs: 1 B1.39: an Evidence at each corner
Surrounds: Rotel 981 -> AR 12 ga -> RTi A3
3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
