Identifying a 1980's speaker model
Kernos
Kernos Posts: 5
edited May 2012 in Vintage Speakers
I have a pair of floor Polks measuring about 37.5" high, 15.5" wide and 12" deep. It has 2 metal tweeters at the top, 3 midrange ~6" and ~12" (or 10") woofer at the bottom.
I thought they were S6's but the dimensions dont match on your vintage models PDF for any of the S series speakers. I need to get a new crossover cable (is that the correct jargon?) for it or make one. The mice have been busy
Any help is greatly appreciated about the model and how to get a cable and connectors.
Thanks,
Bill
Post edited by Kernos on
  • 11tsteve
    11tsteve Posts: 1,166
    edited April 2012
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • stubby
    stubby Posts: 723
    edited April 2012
    Sounds like a pair of SDA 2. Never heard a pair, but they should sound very good.
    If it has the small blade/large blade interconnect cable, they come up for sale fairly frequently here and on flea-bay. Not sure, but Polk may even have them available. Hopefully, someone will chime in who knows for sure.
    And set out the mouse traps or rent a cat!
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • falconcry72
    falconcry72 Posts: 3,580
    edited April 2012
    Hey, welcome to CP!:cheesygrin: Lots of good info here on vintage Polks.
    They sound like SDA-2's. Do they look like this:?
    Their model name, "SDA", stands for Stereo Dimensional Array. The cable is necessary for the SDA "effect" to work. Vintage SDA's are really special speakers, and there's a lot you can do to get more out of them.
    If the cable you need has 2 flat metal prongs (called a blade-blade), you can get it from Polk. Just call customer service and tell them your a CP member. If the cable you need has 1 flat metal prong and 1 circular prong (called a pin-blade), you'll have to look on ebay or make one. If it is a pin-blade, the blade is only there for physical support. To make one, just use a good quality RCA cable and remove the "petals" from the pin so that it goes in the hole far enough.
  • Kernos
    Kernos Posts: 5
    edited April 2012
    Thanks all. Yes thats what they look like. The connectors are blade-blade. Are they called crossover cables? I'm wondering what to tell customer service I need.
    Regards,
    Bill
  • TennMan
    TennMan Posts: 1,267
    edited April 2012
    You need to ask for a blade/blade Interconnect Cable [IC] for SDA speakers. Recently when I called the blade/blade IC was still available for (I think) $40. Pin/blade IC was no longer available.
  • Kernos
    Kernos Posts: 5
    edited April 2012
    Thanks much. I got one!
    Bill
  • boston1450
    boston1450 Posts: 7,758
    edited May 2012
    nice. good information. i like reading other stories. enjoy them
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
