Decent iPod / USB cable for the car - anything available in a short size?
PrazVT
Do you guys know of any makers of higher end ipod/usb cables who offer a shorter length than what is typically available online? Everything I've seen (I guess just Audioquest) is .75meters or longer but I only need one that's maybe 6 - 8" max.
I'm using an AQ Forest one in my car but I have to hide most of it in the glove box which looks ugly. I may be buying a new car in the next few weeks or so and just wanted to see if I could avoid a setup like this.
It's not critical, but I feel that the AQ cable helped improve SQ a bit compared to the coiled Griffon cable i was using before.
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups.
NAD D3020 V2
Schiit Bifrost 2/64
Post edited by PrazVT on
Try DH Labs USB cable. I've never tried it, so can't offer any feedback. I was doing a search earlier today for USB cables and found them. They advertise that they will custom make them from .5m to 5m long. Check it: http://www.silversonic.com/docs/products/USB.html
Thanks Ern Dog. .5m is still like 1.5ft, but hey it's an improvement from .75m! Thanks Ern Dog.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Signal Cable will make one for you.If you can't hear a difference, don't waste your money.
