Pioneer SC Elite Owners. Amp??
tommyt21
tommyt21 Posts: 685
edited May 2012 in Electronics
Hello,
Any Pioneer SC Elite Owners. Have any of you added a external amp to your Elite? Did you notice any ("significant") differences?
Subjective opinions and experience welcome..:cheesygrin:
Seriously contemplating a Amp when my bonus comes in at the end of the next month.
Thanks for your help
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
Post edited by tommyt21 on
  • newrival
    newrival Posts: 2,017
    edited April 2012
    Minor difference, to a point. It depends on the speakers. But the amps in there are pretty darn good. Depending on the amp you buy, there will be a difference. It will be noticeable, but likely minor.
    Others will tell you it will be night and day.
  • B Run
    B Run Posts: 1,888
    edited April 2012
    I think if you had some really difficult to drive speakers or 4ohm speakers you'll hear a bigger difference, but like newrival said it'd most likely be a minor change than a night and day difference.
  • mole'
    mole' Posts: 3,160
    edited April 2012
    owned a SC-07 and have a SC-35 now.
    it all depends on the Amp you add. i have ran a few different amps from Adcom, Acurus, EMO to my Cinenova grade 5. makes a BIIIIIG difference on my power hungry LSi speakers.
    the EMO amps are pretty good prices for what you get out of them.
    http://shop.emotiva.com/
    they are not liked on here much, but i like them.
    mole'
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2012
    I think you'll notice a bigger difference upgrading your center to the a6. The amps in those receivers are very good and true to power ratings.
    tonyb Posts: 33,065
    edited April 2012
    The 7's are fairly easy to drive, and that receiver is pretty good on power by itself. Adding an amp wouldn't be my first choice. Maybe add a Squeezebox or Sonos to the system instead, you may double your listening pleasure that way.
  • mole'
    mole' Posts: 3,160
    edited April 2012
    leroyjr1 wrote: »
    CSia6 is a big upgrade over the a4. DO IT!!!!
    mole'
  • PrazVT
    PrazVT Posts: 1,607
    edited April 2012
    I ran my RTi A7s off of the SC 57's amps while I was waiting for my M25 amp to come in - I'd say compared to the Parasound A21 , HCA2200II, and NC2250 that each powered those speakers in the past, the SC gets you about 75 - 80% there. Admirable job for a receiver.
    I'd agree with tonyb to try to improve other aspects of your system before you blow $$ on an amp.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited April 2012
    Get a good amp with tons of power thats great for music but first get the center swapped out for the big dawg
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2012
    SC07 with a Sunfire TGA5200 for multichannel, and D-Sonic 1000S on the fronts.
  • mantis
    mantis Posts: 17,312
    edited April 2012
    leroyjr1 wrote: »
    Ditto
    Dan
  • tommyt21
    tommyt21 Posts: 685
    edited April 2012
    If I had the room for the A6 it would be a no brainer, but i'm stuck for awhile with the csi a4.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • tommyt21
    tommyt21 Posts: 685
    edited April 2012
    Is there still much of a difference between the a4 & a6 when I have it set to small for the center channel?
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • polkfarmboy
    edited April 2012
    Yes
    My first impression was watching a female news caster sitting next to male. As they both started talking there was a dramatic difference between voicing so there is alot going on
  • mufsoman
    mufsoman Posts: 636
    edited May 2012
    There was a difference adding the Rotel to my SC07 setup, but not night and day. No additional volume, just more refined sound. Still would not run without it though. Sound is overall more detailed and lows more punchy.
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
