amp for 2 mm12's
bman36569
bman36569 Posts: 14
edited April 2004 in Car Subwoofer Talk
i got 2 MM12 's in the box enclosures, and im trying to find a polk/momo amp for them. the subs are 500 rms each i think, im not too sure though. i was told i would need two amps for them, not sure if it was the c300 or c500 amps. so if anybody could give me any info, that would help me alot!
Post edited by bman36569 on
  • Systems
    Systems Posts: 14,872
    edited April 2004
    well this is weird couse that c500.1 amp puts out 500 wattsx1at 2 ohm and 350 wattsx1 at 4 ohm and them subs are 4 ohm subs.and the c300.2 puts out 500 wattsx1 at 4 ohm but thats bridged.id try and go with another amp like phoenix gold if i were you.
    Testing
    Testing
    Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2004
    you were probably rec'd two 300.2 amps, they will match your subs quite well.
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    thanx for that info, but could yall help me with this other question? im thinking about getting the mm6 midbass with the tweets, would i need to get a c500 amp for that? and what would be the best way to set up my mm12s to get the best sound
  • Systems
    edited April 2004
    well as i am told the sealed is the best for the mm12's
    Testing
    Testing
    Testing
  • neomagus00
    edited April 2004
    mmm... no, the 300.2 is best for the mm6's too. and yes, sealed will give you the best sound quality out of any subwoofer. the momo subs can't handle anything else, their suspension is too dependant on the sealed system (which isn't a bad thing, they are a damn fine product, they just have to be in a sealed box).
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    yea i still have the subs in the original sealed box. but i was wonderin which way i could face the subs in the car to get the best sound. Will the two c300 amps power the two subs and the mm6?...i appreciate all the help
  • neomagus00
    edited April 2004
    no, for 2 subs and an mm6, you'd need 3 300.2 amps total - one for each sub and another for the mm6s. generally, you face the subs towards the rear of the car when the box is up against the rear seat/bench. this gives the sound a bit of room to expand (or this is a good concept to keep in mind anyway). then, you check phase from there.
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    ok..when ya buy a mm6, thats only one speaker and one tweet right..so if i wanted one on each side of the car, i would need four amps in all? thats goin to be pricey
  • exalted512
    exalted512 Posts: 10,734
    edited April 2004
    no
    when you buy any set of speakers you get 2 of everything
    except subs
    but if you buy some 6.5" speakers, you get 2 of em
    if you buy a component set(the mm6 is a component set)
    then you get 2 6.5" speakers, 2 tweeters, and 2 crossovers
    that is the mm6 set
    its not 1 6.5 and 1 tweeter
    and you need 1 amp to power the mm6 set
    -Cody
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    o alright, thanks. sorry for these stupid questions..im kinda new to all this..
  • neomagus00
    edited April 2004
    we all were at one point (hell, i still am). at least you asked and saved yourself some cash.
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    haha..well dont be exspecting this to be my last questions..im sure i got more to come:D
  • neomagus00
    edited April 2004
    ask away, we'll be here...
  • exalted512
    edited April 2004
    isnt that on an allstate insurance commercial?
    -Cody
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    ok then..what would be the best wiring kit for all of that?
  • exalted512
    edited April 2004
    for just 2 mm12s, 4 gauge should do you good
    www.knukonceptz.com
    -Cody
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    i hear all the time that people blow the mm12's. howcome it takes so long for them to break compared to other subs?
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    oops, meant howcome it takes so long to break them in...my bad..
  • exalted512
    edited April 2004
    they have an EXTREMELY stiff suspension
    why?
    i dont know...
    but they do
    -Cody
  • neomagus00
    edited April 2004
    -Cody
    i dunno, i've never heard it; maybe i'm destined to be an insurance salesman
    if you're looking to upgrade the subs or other speakers later, to something much larger, you may want to step up the wiring (bigger wire/smaller gauge number). just a thought.
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    would you still recommend the wiring on that site you gave me, or monster cable, they any good?
  • exalted512
    edited April 2004
    knukonceptz has awesome wire
    im pretty sure its the cheapest youll be able to find it
    the momos need a 40 hour break in period
    -Cody
  • neomagus00
    edited April 2004
    40 hour minimum. as long as you can stand it, for maximum assurance of durability.
  • bman36569
    bman36569 Posts: 14
    edited April 2004
    i heard alot of people say around 75 hours. sounds like a long time to me, but dont think i need to do it that long will i? i know that will break them in correctly..but still ya know..
  • exalted512
    edited April 2004
    75 hours?
    ive never heard that
    40 hours is a good number
    -Cody
  • neomagus00
    edited April 2004
    i believe it was thomas that recently gave the guideline of "1/4 volume for 2 weeks, then slam the **** out of them." sounds good to me.
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited April 2004
    what easier is just to have good self control:
    set your amp down to 1/4 of what you're going to run... play that for a while, you'll get used to having real sound...
    then turn it to 1/2 for a while, then 3/4 , then 100% of what your reg listening will be... This is much easier than trying to force your self to listen to it really low... I know I cant.
    But nevertheless, i re-break in my old DB12's anytime i've had em out of the car for a while (I plan on keping them)
    --Jerry
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • exalted512
    edited April 2004
    i have no self control
    the subs in my truck are numbers 5 and 6
    blew out 1-4...oops
    i cracked the spider on the original mm120s...no idea how i pulled that off
    they gave me the mm12s which started hitting the grill
    they had a recall on them at the time b/c they were hitting the grill so i sent them back
    got my new ones and they still hit the grill
    maybe they should recall the grills?
    -Cody
  • LittleCar_w/12s
    edited April 2004
    LMAO Cody. Yes, what IS up with the grilles not handling the XMax... they know we're going to use all the susp. those mm's have.
    -Jerry
  • neomagus00
    edited April 2004
    since the grilles are touted as being based off of momo's quasar 2 wheel, maybe the idea was more form over function, and that the whole sub-has-to-work thing was more of an afterthought.
