CSi A6 match?
Will any RTi speaker be a good match for my CSi A6? Are there other options too?
Thanks!
Thanks!
Post edited by wyldlife on
Here's the RTi line up you can mix and match...
RTi A Series Models
Floorstanding / Towers
RTi A9
RTi A7
RTi A5
Bookshelf Speakers
RTi A3
RTi A1
Center Speakers
CSi A6
CSi A4
Surrounds / Rear Speakers
FXi A6
FXi A4Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
In other words, all of them.Here's the RTi line up you can mix and match...
RTi A Series Models
RTi A9
RTi A7
RTi A5
Bookshelf Speakers
RTi A3
RTi A1
Center Speakers
CSi A6
CSi A4
FXi A6
FXi A4 -
In my opinion that big center would sound best with the A7 or A9.
Old SDAs and monitors (7 and 10) would also work well and would save you some coin. They are also amazing for 2 channel listening.
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded -
Aren't the older rti speakers a match as well? Ones such as rti 12 and rti 8 .... Sonically anyway?Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
the RTi12 is pretty much the same speaker as the A9 with perhaps some minor crossover changes...
Although, obviously the enclosure changes the sound a lil bit too- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I am thinking RTi 8 if it's a good match. I would love the A5, 7 or 9 but I can't afford those.
I had a csi6 matched with RTI 12 fronts and fx4's for rears and they sounded great together. Super for HT.
used the CSiA6 with my RTi10 and SDA 2.3TL. sounded greatmole'
