CSi A4 No s/n label
Just got one of these center speakers from Amazon and the s/n label has been removed. They left behind the sticky stuff but no label. Should I be concerned?
THX,
TJ
THX,
TJ
Yamaha MX 800, CX 800, EQ 630, TV 930, Pioneer PD-M6, Polk RTi A7, RTi A3, CSi A4, DSWPRO550wi
It's Go Pens!!!
It's Go Pens!!!
Post edited by p51tj on
I bought a couple of FXi A4's a couple of years ago on the internet and they came with the serial numbers peeled off. Made me wonder why they had to do that. Had them for about 6 months with no problems, sold them to a neighbor and they are still working just fine. When I did a review (might have been Amazon) I raised the question about no serial numbers. I have always wondered if these were stolen or what. Since then I try to make sure I buy from an authorized dealer just to make sure there is a warrenty if nothing else.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
THX Zane, and what adds further intruige is Amazon is an authorized dealer/seller. Called Polk and they said shouldn't be a problem as long as I got the S/n card. I have also called Amazon and they will be sending out a replacement. Let's see if this one will have the s/n's peeled off.Yamaha MX 800, CX 800, EQ 630, TV 930, Pioneer PD-M6, Polk RTi A7, RTi A3, CSi A4, DSWPRO550wi
It's Go Pens!!! -
Mine didn't come with the serial number card (the yellow one) in the box. Still makes me wonder where those came from.Home Theater
Two Channel
Thankfully, it did come with the S/n card.Yamaha MX 800, CX 800, EQ 630, TV 930, Pioneer PD-M6, Polk RTi A7, RTi A3, CSi A4, DSWPRO550wi
It's Go Pens!!! -
Called Amazon and they sent me a new one...this one had the S/n label. So now time to send the original back to them for a credit and all is well with the world again!
It's Go Pens!!!
