Looking at new cars soon and....
kevhed72
I am actually considering having Polk speakers and a decent 'setup' for audio put into the car....as I now find myself doing alot of music listening on the road. I don't think I have even been to this section of the forum...sooo, where do you all advise I start.....Polk speakers, amp, CD player. Again, I am clueless.
Also, my new car will have zero room for amps or subs to be put in the truck on anywhere else vs. the typical placement in the dash. Thoughts....:question:
Post edited by kevhed72 on
It all depends on how far you want to go.
(1) Do you want something that is just pretty good to listen to. Upgrade the factory deck, change the speakers, add sub, and amps. I would go with MM speakers, they are great for the $, (200 for 6.5 inch components). If you want small amps I would look at Alpine Pdx.
(2) Do you want to try to recreate a two channel home stereo experience in your car? This would involve a signal processor that would let you go active, have Left and Right EQ, and time alignment. Alternatively instead of a processor you could just get the new pioneer p80 which has 16band EQ Left/Right, 3 way active crossover, and time alignment.Audison Bit Ten
Kenwood X595
Polk MM6501
Polk MM1240
Mtx 704x
Alpine MRX50 -
I agree with most of the stuff the above post says, however I think the Kenwood Excelon XR series amps are better quality than the alpines. They are also smaller.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
