'Entry Level' DAC Comparison
13»
    heiney9 Posts: 25,405
    edited February 2012
    Danny - when you get a chance maybe we could figure out which version of the Keces 151 you have on loan.
    The original dac was called the PCM2702 and had an all acrylic case with the Keces logo engraved on it. The dac uses the clock on the chip also had output coupling caps and used OPA604 op-amps Many people didn't care for the logo to be so prominently displayed.
    The next version called the DA-151 used a little better power supply, an outboard upgraded clock (rather than the on chip clock). Still had the output coupling caps, but replaced the OPA604 op-amps with the more neutral LME47910 op-amps. It came in a nice steel case with a thick smoked plexiglass top and a smaller logo on the front.
    The DA-151 MKII uses the identical case (no "MKII" markings) but the output coupling caps are replaced by a single op-amp, better power supply, clock is closer to the chip for an even shorter circuit path, optimized circuit board layout and external voltage switch
    It would help to know which version you have. I have the second one
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    I don't know specifics about the chips used in each one, but the version I have is apparently the new one, it's the one in the second photo. I may have mentioned this already, but I'm using an iMac as my primary source. iTunes doesn't do sample rate conversion though and generally sucks almost as much as the awful Windows kmixer driver so I'm running Amarra Mini to bypass all the iTunes garbage.
    Amarra is generally considered to be the best audio engine for the Mac platform, though I've also used Pure Music with great success. I've just recently acquired Amarra Mini and prefer it over Pure Music only because of the interface, audio playback is very similar between the two.
    So I'm covered on the USB front, I'm getting the best possible output via USB that one can get with a Mac, and alot of 'pro' reviews are done on my same setup, for whatever that's worth.
    FYI, the second photo with the visible coupling caps is the revised original version. The last photo is the MKII version and is the current version. Do the best you can with the USB connection. I know very little about Mac and the interphase.
    Thanks for taking the time to do this.
  • FTGV
    FTGV Posts: 3,650
    heiney9 wrote: »
    ... with the more neutral LME47910 op-amps.
    A good'n and my favorite along with the dual versions LM4562/LME4792O.Tansparent,detailed and very low noise but some may find it a little too much on the analytical side.
    FTGV wrote: »
    So far not an issue, but I am still evaluating. I may pick up some OPA604's and swap just to see. According to Keces, no one has ever asked to put the OPA's back in after hearing the LME47910's.
    Fred, I still have those op-amps you sent me for the Pop-Pulse dac. If you'd like them back I can certainly put them back in the mail to you. Right now I don't think I have a use for them. If not, I'll keep them in my goody box.
  • FTGV
    FTGV Posts: 3,650
    Nah it's OK Brock keep em in your goody box or pass on to someone else wanting to try rolling opamps.
  • [Deleted User]
    [Deleted User] Posts: 1,225
    FTGV wrote: »
    What's the slew rate on your op amp rolling ? Sorry, engineering attempt at humor. :cool:
    tonyb Posts: 33,066
    nap wrote: »
    You dudes have ......humor ?? Well I'll be....!!
    I think it's more so a byproduct of you hanging out too long in here my good man.
  • sucks2beme
    sucks2beme Posts: 5,681
    Updates?
    Dog ate your homework????
  • sandworms
    sandworms Posts: 1,043
    Man, I can't hold my breath this long!! We need updates!
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • Drenis
    Drenis Posts: 2,871
    heiney9 wrote: »
    Can you PM me about what these do? I happen to own a Pop-Pulse DAC :razz:
    EndersShadow Posts: 17,687
    edited March 2012
    bump....
    edited April 2012
    anything ever come of this.....
  • dragon1952
    dragon1952 Posts: 4,907
    edited April 2012
    zzzzzzzzzz
  • jgscott
    jgscott Posts: 10
    edited April 2012
    What the outcome ?
  • DarkHorror
    DarkHorror Posts: 73
    edited April 2012
    Did you get a chance to do a full test and how did you do the testing?
